I don't think I saw you :( I didn't get a 1.4L, if you can stretch your budget a little further the 1.5L is much punchier and better on fuel. Better brakes as well. The 1.5L has a completely different engine & transmission (same as the Tiida) to the 1.4L (same as the Micra.) Also the CVT auto is better than the standard 4-speed auto. But they are a fair bit more expensive. My 1.5L 7-seater was over $17K on the road, and that's at the cheaper end of the scale (the 1.5L 7-seater is the most expensive.) Mine's a 2005 model :)
yeah i wasnt looking to spend that much, ive been looking for comparisons between the 1.4L and 1.5L but havent found much other than what youve said which is its more punchier, 5 or 7 not really phazed, the one i was looking at had the woodgrain interior as well though you could most likely just buy that through nissan for any of them ah well, probably looking at a 95/96 micra now anyway the cube is a bit too much to spend for a daily (i live in croydon north and work in chirnside), this is my inspiration lol :P
Bah just buy a secondhand n16 pulsar for 5-10k. Much better car than micra looks wise (the new micra I'm referring to of course) 1.8L of awesome :P 5-600 km per tank on 91ron. Best na car I ever owned.
That's what i'm doing in July.
I can haz Sierra Cosworth?
fkn amature move.
go to UK, buy a $30 flight to Netherlands, buy a brand new RHD Merc/Audi/BMW in pimp spec limited edition (something hard to get in oz, like one of those 11ty hp turbo diesels or someshit), jump on a ferry back to the UK.
BAM, car in the UK without paying retarded UK taxes.
A year later... BAM, car in oz that is worth double what you paid for a year ago. Flip it and do it again for the other year of your remaining visa.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
