That guy has to be the ultimate troll. No way is that vid serious.
I'm not so sure..
Volt
Free
Anything goes
Volt entry is actually something ridiculous like $15...Should be free because it's a hole, but people do actually pay to go in there...
Not every thought in your head should be reproduced verbally/electronically etc
You ain't gonna get poon typing phaggotry like that
I like this guy. :cheers:
I appreciate it man, but I don't really need advice on "how to get poon" :thumbsup:
Also not too worried about what girls on here think of me :P
the ones who things up the most are usually in reality the exact opposite. :whistling:
its like theres pretend rich who brag an shit then there is real rich who dont say anything but you just know they wipe there ass with silk
wiping asses is for peasants.
Bidet and douchettes brah.
Shan where you been homo.
Also
fight fight fight!
Rimon v Jeremy
Why...
Kunts shoot down 11ty ducks and it's all good
Kunts stone a swan and it makes the front page of every paper
Racism towards the ducks.
Why?
I tend to agree with this. I just don't mention money coz I'm a poor kent :P
Anyway, I'm off to get my drink on with Birds and crew. Have a good night people!
Edited by jezza boii
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
