Did the MR get all the fancy pants timing stuff?
cant remember
there was a vid on youtube that explains all the extras that it has over a normal evo 8 and does a bunch of tests with it too
was actually pretty good to watch, test an sti, nsx and some others if i rememeber correctly
From what I see they range from 30-40k depending on condition. Don't quite look as good as the E46, but I'd take a Benz interior and smoothness in daily driving over the M3.
