the dating thread in the wasteland is about to get popcorn worthy ;)
F**k yeah...please tell me it's staying open for teh lulz. Would be a lot funnier if it was one of the fat ones though...this chick doesn't really have much to complain about.
I can promise more lols to come, that's all i can say for now :thumbsup:
the best.
lightly braise chicken in a master stock by laying it on a tray and pouring the boiling master stock on top (you can google a master stock recipe)
allow to cool fully
strain
dip chicken in fish sauce, then place in rice flour
deep fry chicken in peanut oil
toss in bowl with home made sechuan salt (salt with roasted sechuan peppercorn, clove and anise)
add corrinder, chopped chilli and spring onion
serve
you wouoldn't like it as it will usually be in 180-200g portions MAX
the shit is $40kg wholesale (so double for retail) for sashimi grade
also most place f**k it up :/
Thanks for the recipe. Saved, will try it on monday or some shit.
And where get i get sashimi grade tuna for 40/kg wholesale? Yellowfin or bluefin?
How much more for the belly cuts?
well to get wholesale you need to have y'know like a restaurant etc
belly flap is less as it's shite, i'm talking about loin
My uncle buys so much Sole Mare tuna that he now deals directly with the company instead of buying from Safeway. I thought it must be good and went out and bought 10 cans. Couldn't stomach it for some reason :( John West is what I eat each day now.
Anyone who eats it regularly and has half a brain does that. I buy it by the slab, works out about half the price of supermarkets
Pretty sure its sole mare or John west that make a tuna in 'light' oil which is apparently better for us fat kunce. I've tried it, it's pretty good too.
NOt sure how u get fat eating tuna in olive oil...
i see. Sole Mare comes in 130g cans yeah? will give it a try although i like the no drain John West just coz it's less messy but pure 100% olive oil is extra goodness
don't really care about the taste
185g cans like every other brand, or the smaller or bigger cans. I get the 185's in a slab
I just get the Sirena chilli - and drain the oil. The 120kg monstrosity @ work reckons it's good enough so i'll go with that lol :)
I generally use the tuna in a sambo, or in an omelette etc. Sometimes just outta the tin if I'm dying.
Hopefully get back into training next week. Finally feeling 100%, been a looong time since i've had energy!
How much you paying for a slab? of 185g cans?
olive oil is still oil, which is fat.
This is what I mean Dezzy. Tuna is fantastic food for fatties. I've lost 2 kilos over the last two weeks. Need to lose another 11 before I f**k off overseas.
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
