why didnt you kill them? i would of in grand theft auto because i dont know the difference from reality and video games.
:rofl2:
oh and Cas I got a major in my old car for 2 things :s had to get a roadworthy no fine though
Hey guys, i need your help !
does anyone have an account for nissansilvia.com ??
it wont let me register for some reason and I'm really wanting to buy an advertised front bar for my 32. :ermm:
if anyone can help me out by using there account to leave the guy my number, would be much appreciated.
oh is that in the big frame to hold it up?
im only at 12.5kg squat
pissweak haha
Yeah in the squat rack, not in the smith machine with the guides on either side. 12.5kg sounds real low even for a beginner, but I'm guessing you're not including bar wright which will be at least 15kg, 20kg if its a full size bar
why do you need to go over 180km/h?
You will most likely fark up your hicas and sensitive steering if you chop the speed signal wire from the ecu. (basing this off r32)
I found out at Sandown my '34 had the speed limiter removed.
Guest
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
