Hmmm... Thinking about buying an R34 GT-4. How easy is it to do an engine swap? Drop in an RB26 and it's essentially a GTR..
Never seen a GT-4 for sale until now. $15k asking price.
As what Shan said...
You could probably get a R32 GTR for a similar price of a R34 GTT.
Or save your money and get the MR2 Turbo.
Yeah I think I will get a stock MR2 turbo. Less cop hassles that way.
Also thinking of getting a shitbox Celica for like $2000 and save all my money for other things (not necessarily cars).
I might take a break from the car scene... We'll see what comes along.
Get an R32 GTS-4 and be a winner like me :ermm:
mine's for sale if you want it.
can supply with stock go fast bits or not depending on how ethnic you get and try to haggle.
comes in 6 different body colours simultaneously.
two owners since new with full books. both owners liked teh go fast pedal.
hahah the abs f**ked up on my gts-4... sounds like someone has had the 4wd fuse pulled out for too long, or has been doing rwd keybangers
mine f**ked up soo badly i coudnt even turn a corner, it would just lock the attessa half way between and it was like jaming the breaks on while trying to perform a u turn hahaha
nah mine just has one caliper locked permanently. It compresses, but then doesn't flow backwards. Guessing there's something in the ABS lines that's acting as a one way valve. Gonna bleed it n see what happens... just need to get around to doing it.
Err.. Your manual comment is void because I CAN drive manual. Would you like to see video of me driving my workmate's MR2 tomorrow? Major inconvenience but I can do it on my lunch break. Would be worth it to prove you wrong... :(
FYI, I don't want to have internet arguments. They're gay. So after this reply just leave it kthx.
Oh and I have driven SAU people's cars before. First one I ever drove was Chad's 32 and he will back me up if he reads this.
If I managed to handle that clutch I'm pretty sure I can handle a standard one :(
If I managed to handle that clutch I'm pretty sure I can handle a standard one :P
wow panties in a bunch, post up saying you don't like internet arguments and you keep goin on fb and SAU :P nice.
lol standard. yes :(
never go into first gear
only go into first gear when you are stopped
if the vehicle is moving, the lowest gear you should select is 2nd
again this would be from sub 30/40km/h
you dont need to downgear in sequence but dont go from 4th to 1st or 2nd
theres too much ratio difference. if your in fourth and slowing down, goto 3rd and brake a bit
use both to slow the car down. not one. if you stick with using one (ie engine or brake)
when you need to emergency stop you wont clutch in, which will mean the car wont stop for peanuts
in an auto when you brake, the engine is disengaged from the clutch, so you stop normally
if you do the same in a manual ,the car will pull up heaps slower and take much longer, cos the engine and clutch are still engaged. ie like slowing down a spinning wheel whilst someone is still pedaling behind on it (on a bike)
Guest
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
