the only people who'd be envious of your R32 are 4 year olds on tricycles cos you have 1 more wheel than them. However even they don't need their mum to supervise em while driving, so I'm sure they too wouldn't be envious of your shit.
i actually agree.. its an old r32 taxi haha
whats to envy
i was thinking of buying a front pipe for the gtr but im not sure now because the stock one doesnt look that much different to the aftermarket ones, plus they say that the dump pipes are good in the r34gtr so i dont have to worry about that either. maybe i should just get an aftermarket ecu instead.
R34 GTR Dump Pipes will be fine, but I'd change the front pipes (get a full / turbo back exhaust).
I did on my R32 GTR and the exhaust flow is so much better.
You could do ECU, but if you don't have any extensive mods, it's not much point as the stock ECU can handle what it is doing.
ive already got the catback and got a new cat ready to be put in. but after looking at pics of a stock r34 gtr front pipe and aftermarket ones i dont see much difference and the sizing doesnt look small either so i just dont see much of a gain for the price of these things. so i thought id just put it towards an ecu instead and help with the very rich tune it has. but if anyone knows better with r34gtr's and there front pipes and what i should do id like to hear from them :P
get a blow of valve that goes sututututu
it. gets. bitches
you have no clue
im not after bitches im looking for broad minded persons.
edit: ok it doesnt let me say s-l-u-t-s
sluts
uras kit acquired.
thought you were selling?
go to any club on a friday or saturday night
you have no clue
being sarcastic mannn
sluts
ahahah i know the secret!
Guest
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
