DECA aint too far away. i'll be heading up on friday, havent decided what time yet, probably round 9pm. who else wants to cruise up?
i'll get details down once we get a few responses
ill be heading up on friday night. 9pm might be too late? By the time everyone meets up it will be like 9:30-10pm before we leave. 3hrs of driving and arrive there around Midnight and waking up Bec for keys to the room /guilty :P
I reckon meet at 6:30pm, leave at 7pm. Get there at 9:30pm-10pm. Eat dinner and go sleep.
yes/no?
https://www.sau.com.au/forums/topic/311509-deca-premeet-se/#findComment-5128690
I'll tag along.
Which comes second, the BP or Shell? We should meet at the second so that those who wish to fill up at the other don't have to turn back.
Ones on the Hume are Shell at Donnybrook and BP at Wallan (newish and the second of the 2). There is a BP at Somerton, Cooper St but that is off the main drag but can be seen from the highway.
https://www.sau.com.au/forums/topic/311509-deca-premeet-se/#findComment-5128773
well im cool with an earlier meet up, but i finish class at 5 in box hill. will be a stretch unless of course i get everything ready the night b4, which is a nice dream lol. plus im giving a lift to two other curries. we run on a different (read slower) clock
https://www.sau.com.au/forums/topic/311509-deca-premeet-se/#findComment-5128914
better start packing son :P
https://www.sau.com.au/forums/topic/311509-deca-premeet-se/#findComment-5128961
i agree with pat :cheers: also where is the initial meet up point? also if i dont enter maybe i could get a lift with one of you guys? not sure yet if im entering or not..
I'd offer you a lift but that'd just encourage you NOT to enter.
If you're desperate though you can sit in the backseat of the Supra (already bringing a mate), mind you they're twice as bad than Skylines for leg room.
https://www.sau.com.au/forums/topic/311509-deca-premeet-se/#findComment-5129543
damn, lift with Basti fell thru, can I scab a lift off anyone else that's staying for both nights?
You're welcome to squash into the back of the Supra, if you can handle it for several hours.
Might be able to jump into another car at Wallan which is only... an hour and a bit from Dandy.
https://www.sau.com.au/forums/topic/311509-deca-premeet-se/#findComment-5135789
im staying both nights mate. beware you will want to die by the time we get there i have no trim in the back so lets just say it gets a little noisy... (no radio either.. :) )
sent u pm.
https://www.sau.com.au/forums/topic/311509-deca-premeet-se/#findComment-5138132
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
