Hey all, I'm thinking of grabbing some Polycarbonate windows from the UK while the exchange rate is so good, but was first wondering whether anyone had any experience with 'Platics 4 Performance' ( http://www.plastics4performance.com/default.asp ), or secondly, whether anyone has had them custom made here?
The rear 1/4 windows on the 180 are a bit odd so would be quite difficult to do I would think. The full kit is appealing, and is pretty reasonable considering the bulk of it.
Glass on the 180, for reference:
Cheers,
Dane
https://www.sau.com.au/forums/topic/311609-polycarbonate-windows/
  • Replies 65
G'day Dane,
I was looking into the same thing with the windows, and you can get ones that are direct replacement for you standard front side windows. They bolt into the window rail and go up and down just like factory ones. The mob in the UK have them and I think a supplier here in OZ was selling them on nissansilvia.com. (can't remember their name) They were asking something like $250 each though.
As an alternative, you can look at acrylic based perspex as a cheaper option. Just be aware that when replacing the standard glass windows with plastic, they may not seal as well against the rubbers. That's one downfall of frameless doors!
Try this guy also for quotes. www.plastix.com.au
I spoke to him awhile back and he said they will make anything including windows for cars. Can mould to any shape and cut to any size. Hope this helps.
Cheers
Mark
Edited by nismoman
Thanks for the information Mark, much appreciated.
The guy on NS who sells them is TAARK, but at $250 each I'd much rather grab the kit for 1k AUD or thereabouts as I think the rear 1/4's and rear windscreen would be by far the more expensive items and slightly more difficult to have made up. I also don't mind if they don't go up an down as I'll be optioning them with the slots and getting a roof vent, and the car is no longer road registered.
I might speak with Plastix.com.au as well to get another quote and help confirm which way I'll go. Another part of the appeal from Plastics 4 Performance is that they do the black surrounds as per the stock glass, and can be purchased with a grey tint which looks pretty nice :cheers:
Troy: It's looking a bit sad at the moment mate, dented roof, no engine and dusty :laugh:
But I just put a fresh Carbon bonnet on it about 5 mins ago so it's getting better!
don't bother mate, plastic windows are dead easy to form on top of the standard window with a heat gun. you cut a rough shape, then lay the plastic on the standard window, heat until it shapes onto the standard one then mark and cut to fit. yes they end up out of shape by the width of the plastic but it should be no real impact for race car use (ie not a show car seal)
3mm or 4mm for framed windows like rear and 6mm for frameless if you want them to go up and down and seal(ish). You may have seen pics of Mark Berry's old 32 with too thin plastic flapping around in frameless doors
we went a little different and added ally frames to use 3mm plastic, was lighter all up. but fixed windows like rear 1/4 are dead easy.
Cheers Duncan, but I'm not sure if I'd trsut myself to be able to pull it off and still have it looking relatively neat (I'm a ricer at heart :cheers: ), but you've made it sound all pretty easy. Do you have any pics of your frames?
I have seen the image of the 32 with the windows flapping around. What is it that has caused that, apart from the lack of a frame? The NACA duct perhaps?
id be heading duncans way with the door windows. either make a aluminum frame for it or weld a bit of rod to the door with tags to give it a frame as such. ive seen this done numerous times. the advantage of doing it this way is that you can flex the perspex and secure it to the mounting tags rather than heating it because once you heat it it starts going out of shape and becoming blured/wonky to look through.
we run perspex on one of the circuit cars and it was done with a heat gun and its pretty wonky. it also has no frame and requires a strap to hold it in.
for the quarter windows ive been wanting to make up some carbon fiber pannels to replace them. if you sit in your car all strapped in have a look in your mirrors and moving your head and see if you can see anything at all through them. because of seats and cage ect both my quarter windows are useless. and hw cool would carbon look.
That's not a bad idea Troy, wonder if it would have enough velcro contact to keep it in place?
Damo: Thanks for the tips mate, I will keep it all in mind if I decide I'm going to tackle it myself. In the pic it looks like Russ's car has a strap on the top that must have come loose. As for the carbon windows, I know you can get them for a 180SX as I saw someone selling them a few years ago. Should have bought them! I can't see through mine anyway.
if you look at the pic of the 32 they ended up making a strap out of velcro that wraps around the cage. it had come off in that pic. something like that will help keep the top of the window in check.
do as the drag racers do.....nice little frame with tags and bobs your uncle. Im planning on doing my side windows soon.
the piece of 4mm i used for the rear window was $160
Pity I only have a half cage at the moment, but I'm sure I could work something out, and would be easier than making frames for a numpty like me :)
Drag style
All windows cost me under $400 tinted lexan with painted surrounds (lexan can be bent in half without breaking unlike acrylic)
Front 5mm clear lexan
All the rest 3mm tinted lexan
For the surrounds mark & cut the protective layer off & dust on 3 coats of acrylic paint (dont go heavy coats it will react)
Window frames are 3/8 mild tube from enzed instead of welding tabs i drilled & tapped the 3/8 tube
Used stainless nuts/bolts but switched to aluminium scrivets so fitting is a 1 person job
For a water tight seal i used 3mm x 25mm sponge rubber
For cleaning lexan/acrylic without scratching use plexus
Hope this is useful will knock over this job in a day.
Drag style
where did you get the lexan from?
Edited by -==L=a=N=c=E==-
  • 2 years later...
Thread revival.
I was planning on getting the lexan window set from plastics4performance and wanted some advice.
Stick to thicker lexan on the door windows (5mm I think is the thickest) and thin (3mm) on rear and quarter windows?
Should I stick to the clear polycarbonate? What does grey polycarbonate look like?
I think I'll go for the black OEM border on the back 3 windows.
For ventilation I am thinking of either the NACA duct or pop it vents. Any advice? I noticed in the video above that the Advan R34 has 2 naca vents. Drivers side lookes like it drew air in and passenger side looks like it lets air out. Does this work well?
http://www.plastics4performance.com/Lexan--Makrolon--Perspex-race-and-rally-windows-and-window-kits/NISSAN---Lexan--Makrolon-polycarbonate-windows/NISSAN-SKYLINE-R32/Polycarbonate-window-kits/NISSAN-SKYLINE-R32-POLYCARBONATE-WINDOW-KIT/p-288-420-426-797-622/
    • I sense an out of control build thread coming up lololol. That 450kW goal will end up being 600 to 700kW LOL.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
