I have tried two types of coil packs, firstly superspark, now with these, i will just go ahead and say they are rubbish, because i bought a set and they failed after a couple of months, then i took it for warranty and they sent a few spare ones, they worked for a while and started missfiring again. i would just stay clear of these ones!, Now the second brand was splitfire, i have had no problem what so ever with these ones, so it prooves the superspark ones are shit quality, you can even see with the mould quality with the two brands. Just pay the extra $200 or whatever and get splitfires, it will save you money and hassle in the long run.....
https://www.sau.com.au/forums/topic/312273-superspark-coils-rubbish/
The yellow jackets from perfornance wise are also good coils, lots of ppl on GTRC using them.I also have yellow jackets and have no complaints.
well then i guess thats another good brand, i was thinking of getting them, but wasnt sure and didnt want to risk it again....
ive got them and holding up with 300 rwkw's worth of drift car...so far so good.
I must have gotten a bad batch or something, thats still pretty bad because i paid $499 at autobarn... they arent really that cheap either, for the extra $150 or so i would rather the splitfires....
all the china coils are from the same factory with different colours and branding but the same coils
in 7 years of selling splitfires ive had 1 s15 coil fail after 1.5 years of use on a heavily modified engine
we sell at least 50 sets per year
my favourite china coil story to recount is the car that came in with a bad misfire and the china coil had melted into a pool in the spark plug valley
classic!
Edited by autoworx
classic!
lmao!!!!! that sounds about right, where is splitfire made in japan or usa or something right???
i agree with the supersparks. the dealer purchased these and put them in my car before i bought it and they failed in a few months so i bought splitfires and have had no problems since.
yer exactly the same problem with me, only worked for a few months and then failed...the splitfires even feel more smoother than the supersparks
classic!
That is not true. Yellow Jackets Coil Packs are not made in the same factory as the other red ones.
Please get your facts straight before stating so publically. Thanks.
I used to sell Splitfires for around 3 years (approx 80 sets/year) and have had at least 3 sets returned due to faults in that period.
I now sell around 370 sets/year of Yellow Jackets and have had only 5 coils (not sets) fail in that period and we threw them straight under the microscope for testing and the "wrinkles" were identified and ironed out immediately.
I say why waste $800 on coil packs when u can send your coil loom to me and get a wastespark setup for 200 and never have a problem again makes sense saves dollars why wouldn ya
$800 for coil packs? Where on earth do they charge that price? :blush:
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
