lol gotta love the police.. On my way to bball tonight was at the lights waiting to turn right..then i see this car coming from behind in the lane next to me but he didnt come nxt to me so i thought it was abit sus...look over my shoulder n i see the lights on the dash. Obviously an unmarked...good thing is my windows r tinted so they couldnt tell if i looked bak then i see him reverse n get behind me...(i wonder why) so lights go green n i pull into the first driveway n off they went...there so dumb..obviously expecting me to do somthing stupid.
Just dont be stupid guys n ull be fine
  • Replies 111
What a great turnout :D it was good to see everyone again and to meet new faces. Sorry if I still don't remember your names!
That pizza looked mighty nice haha, I thought Charlie had a silver 34.
How was the cruise? I thought someone was following me when I didn't follow you guys on to the freeway haha.
Was a great turnout great to see so many skylines in the one spot burning that I couldnt have come with my own one since stil no lincense for antoher 2 months, but yeah good event
that was me... i went straight to get onto whitehorse road.. im from the bottom of mnt dandy. no running on long w/e with the ps up haha. was a great turn out good to talk shiz... charlis idea was wiked. pizza/carwash meet.
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
