Has anyone installed a cruise control on an R33. What brand, supplier etc and most important, does it work.
Asked about Nissan ones [eg ex Maxima, pulsar etc], but nobody seems to be able to give a first hand account or answer.
Be handy for trips down the Hume or Sturt Highway's etc.
https://www.sau.com.au/forums/topic/31314-cruise-control/
Tried that, talked to Darrin at Just Jap, and yeah, he agreed that there is *some* provision for one in the R33, but he'd never seen one fitted.
Even in the owners handbook they mention how to operate the cruise control [where fitted].
https://www.sau.com.au/forums/topic/31314-cruise-control/#findComment-632266
I wouldn't mind cruise as well.....the only one i have heard about is an aftermarket unit that interfaces with speed sensor and tps directly (no need to hook up the throttle cable etc). The controls are radio (or iR?) and can be steering wheel mounted.
Anyone know the company that makes these?
https://www.sau.com.au/forums/topic/31314-cruise-control/#findComment-649143
hey i was desprate for cruise control too, cos i do heaps of freeway driving etc... but i had another idea...
what about getting an adjustable speed limiter? that way you could have it off for track days :D max speed >180KM/hr and you could say adjust it to 110km/hr for freeway? then you would just have to hold the accelerator? so its not comlete cruse control but it would help? you could also set it for 60km in the city etc...?
https://www.sau.com.au/forums/topic/31314-cruise-control/#findComment-649206
Supercheap in Qld carry one....but it connects up via the throttle cable.  I had it half set up but now i've changed to a front throttle body i'll have to start again. Fairly low on the priority list at the moment.
Jay do you have any more details on this?
Brand? Price? Ease of installation?
https://www.sau.com.au/forums/topic/31314-cruise-control/#findComment-649215
You can use the cheap one they sell at autobarn/supercheap, around 200 gets you the complete kit, I have used one for years and had no trouble, in fact, I think these units are more accurate than MANY factory ones.
Its a vacumn one, meaning, it has a vacumn line from the manifold, (thru a one way valve) to a pair of valves and a large diaphram connected to a cable - to your throttle.
You also put in a pickup coil and magnets on yoru tailshaft.
I went one step further and put on two racy looking push buttons on my steering wheel, wired them up to a small UHF transmitter key and hid that in my steering wheel. Wired up the UHF reciever unit under the dash, to the cruise control unit, and wallah, working cruise control.
When activated, the unit takes over control of the speed and keeps it on the speed you set it at + or - 1km/hr. Preddy darn accurate if you ask me. I dont know how I lived without it.
https://www.sau.com.au/forums/topic/31314-cruise-control/#findComment-649928
yes and yes
altho, for a manual car, you have to install a switch on your clutch pedal so it drops the unit out when you put your foot on the clutch (simple limit switch, any electrician can show you)
this extra switch does not come with the basic unit. You can order one, but its cheaper just to get a limit switch from dick smith electronics and use that.
https://www.sau.com.au/forums/topic/31314-cruise-control/#findComment-650464
Hi guys
rs73 wasn't quite correct, the one I installed was on a R34, not a R33 - but it would work fine on a R33 as well.
.. and the biggest difference you get between the cheaper and more expensive cruise control is how good they work, ie how constant the spead is, particularly overshooting at the top of a hill and slowing down at the start of the hill.. I'm not sure why this is so - it could be the electronics, or it might be the precision of the device moving the throttle cable - but I've found the rostra one to work better than any cruise control I've ever used on any car...
Ian
https://www.sau.com.au/forums/topic/31314-cruise-control/#findComment-650572
Damn I was really wanting a Cruise Control fitted to my manual R33 just to help prevent speeding fines and also to stop my ankle from going to sleep but after looking at Ian's thread it looks like you won't get change from $1,000 :)
If it was <$300 i'd get it instantly but $1,000 .... I gotta do afew more important things first.
https://www.sau.com.au/forums/topic/31314-cruise-control/#findComment-650589
Benm - Then get the command cruise unit from autobarn....they work great.
Like Ive said before I've used one for years and years and swear by them.
I think poeple have to also realise that when you install any cruise control, It must be calibrated to the road properly, or it will overshoot and not stay accurate.
https://www.sau.com.au/forums/topic/31314-cruise-control/#findComment-650710
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
