my best 60' was 1.55s & 129.75mph
i was also running drag radials which made my 60' :(
tyres were compliments of paul & his mates dog (dave) was eyeing out my nads when i returned them lol
i still blame paul for not cracking a high 10 - he told me to hold in 3rd gear across the line...i was on the limiter for almost 1 sec on my good run (paul u baaaad)
  • Replies 186
steve - what back2back tests u doing with yavus, stock v's match ported manifolds?
did u end up going bigger with your exhaust system as well?
Nah no that sort of thing, Pauls referring to his car vs mine as we have a lot of the same parts
Yep the exhaust is going to be a massive step up from the crappy peashooter on there now. I'll get pics up asap for you guys. The best bit? It's specific to rb30 gtr's so no spacers needed :(
and so are uncovered air filters, wheels that are larger than 17inch diameter on an r32 etc etc etc
Check the wheel rules mate, unless they've changed lately you can go bigger than 17's on R32 (vspec2 had 17x9's stock). From memory the rule is 2" up and 1" wider than stock fitment
The uncovered filter rule is pointless with EFI cars. Keep up the good work RTA.
<snip>
Im in for a joint booting from WSID. We can go one after the other in one lane just to make a joke about it. Do you think they'd kick us for slamming the brakes before the finish line?
You could do things a few ways to avoid being booted:
Firstly, you could launch full-steam and back off after half track so that you don't go under 11's. This will give you a decent 60' time and also half-track time and MPH.
Secondly, you could break the beam on the green by creeping forward to trip the start timer...then launch the car and go as hard as you like. This will add to the ET but will give you the correct MPH.
You could then get an estimate of the car's potential by adding the best of both types of runs to see what the car is capable of.
Thirdly, go out for the final run and do a full pass and get booted :D
Then you could go back a couple of months later with different plates and do it all again >_<:D:D
Ideally, you could do this at a private day such as this one:
http://www.skylinesaustralia.com/forums/Ws...ay-t331950.html
and get PLENTY of practice runs in before doing a full pass at the end of the day (or when you get bored) and get the boot >_<
Lol, endurance racing much? That's a shitload of fuel
Or just enough to get you to the shops and back on E85... >_<
Also the wheel rules are so farking weird.
Secondly, the surge tank in boot isn't illegal if it is covered and vented properly. (It really should be setup on a charcoal canister like the tank).
This is the same for the battery, if you don't have a sealed battery it is meant to be enclosed and vented outside of the car (For R33s etc)
Yeah smart move. The 1000's just wont do the job
Why are your drags closing? Is there a racetrack where the straight can be used instead? Eastern Creek used to do that up here. Anyway, you get Targa roads, thats more than enough :)
Tarmak has been having trouble for ages. Now they cant form a commitee and doesnt seem like they have the money to keep it running. The track needs lots of attention and last time I raced, after finishing the 1/4 the run off turned to shit and there was pot holes and weeds growing everywhere.
There are 2 tracks in Tassie, Symmons Plains up north and Baskerville down south. But dont think the straight would be long enough.
Or just enough to get you to the shops and back on E85... :)
Hahaha yeah...with e85 on the cards she will chew a bit...somthing along the lines of 90-100L an hour at full noise
i think the bugatti veyron goes thru a full tank of fuel in something like 9min @ full revs on the autobarn :)
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
