  • 10 months later...
The interior pic....Is that a manual gearbox in an M35 ????
Yes, it is a 350s. So an NM35 Autech Axis body on what is essentially a 350z drivetrain.
You can just see the little "350s" on the right side of the grill in the pic above the interior pic.
And the extra pedal FTW...
The rims are 19x8.5 +22 Enkie GTC01
But thats too skinny, I ordered them online before anyone had done any real experimenting and wanted to be safe. We have worked out with my brothers M35 that 9.5 +35/30 is the ideal fitment - no scrubbing and no rolling necessary.
Although if I were to do it all again I would probably to a little flair/roll and run 9.5 +22
Its only the fronts that are an issue, you can easily fit 11" on the back! haha
what are your brothers rims.
I liked the look of em n thought I might cough*copy*cough lol
but are your running spacers?
He Has Axis Hiro copies. running 9.5 +40 with a 10 or 12mm spacer to clear his brakes.
Mine have no spacers and sit dead flush with the guards, his come out a little, but it looks tough without scrubbing guards
Edited by bbenny
All Clean with new rubber.
Should I do the black headlights? I cant decide if I should keep them silver because the car is dark, or black them out to make it mean...
Never get tired of seeing your car Ben, blue is the pick of the colours IMO. Personally; I woudn't touch a thing :thumbsup:
Edited by Daleo
Stay silver.
Blacked out headlights wouldn't look right with that blue IMO
This is f**king hot...
I guess that front bar's pretty rare?
Nup, you can buy it from Nismo and put in the R32 air ducts yourself.
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
