  • 10 months later...
The interior pic....Is that a manual gearbox in an M35 ????
Yes, it is a 350s. So an NM35 Autech Axis body on what is essentially a 350z drivetrain.
You can just see the little "350s" on the right side of the grill in the pic above the interior pic.
And the extra pedal FTW...
The rims are 19x8.5 +22 Enkie GTC01
But thats too skinny, I ordered them online before anyone had done any real experimenting and wanted to be safe. We have worked out with my brothers M35 that 9.5 +35/30 is the ideal fitment - no scrubbing and no rolling necessary.
Although if I were to do it all again I would probably to a little flair/roll and run 9.5 +22
Its only the fronts that are an issue, you can easily fit 11" on the back! haha
what are your brothers rims.
I liked the look of em n thought I might cough*copy*cough lol
but are your running spacers?
He Has Axis Hiro copies. running 9.5 +40 with a 10 or 12mm spacer to clear his brakes.
Mine have no spacers and sit dead flush with the guards, his come out a little, but it looks tough without scrubbing guards
Edited by bbenny
All Clean with new rubber.
Should I do the black headlights? I cant decide if I should keep them silver because the car is dark, or black them out to make it mean...
Never get tired of seeing your car Ben, blue is the pick of the colours IMO. Personally; I woudn't touch a thing :thumbsup:
Edited by Daleo
Stay silver.
Blacked out headlights wouldn't look right with that blue IMO
This is f**king hot...
I guess that front bar's pretty rare?
Nup, you can buy it from Nismo and put in the R32 air ducts yourself.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
    • I started removing the tank a while back with the intent to give it a proper clean. Got to a bolt that I couldn't undo completely due to a diff being in the way, so just said f**k it and siphoned the gluggy old fuel out and called it a day. Looking it the tank it looks less corroded than the one in the pics for that billet hanger from Frenchy's anyway. Isn't it the fuel filters job to worry about this stuff? I scraped off most the crusty shit of the hanger but will give it another go before reinstall coz maybe the fuel and return pipes are also full of gunk
    • Pretty sure it is a common fault. I believe this is the only part you need, but don't quote me as I don't have a V36.  I also believe it is a bit of a pain to change and the device needs to be encoded to the car once it is replaced, so may need someone with the right tools. Buy Genuine Nissan 48700JF00D (48700-JF00D) Lock Set-Steering. Prices, fast shipping, photos, weight - Amayama
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
