A little? lol... A LOT!
I just wish I new where to start, it's got everything it needs to make a decent number, but it's knock restricted.
When jez tuned it last the exhuast was way to small, now that I've got a bigger system coming from jap and I made some 3inch tuned length front pipes into a 4inch merge. The exhuast issues should b over, so it's back to jezza's shop to c if there's any gains.
Strange thing is, I had a 4inch system made, and we chucked it on the dyno, only got 7kw gain with adding timing and boost.
C what happens, maybe we need to play with the cams, or something.
Depends what manifold you get.. The Full race one I have was designed for fitment on 33/34s. Tried putting it on my 32 and the compressor fouled on it..apparently full race have rectified this for 32s now
A/C didn't work anyway so I'm not too fussed, then again I may have wanted to fix it one day :s
I saw a dyno graph from a famous 32 on the weekend. It's now running a Precision single (6766 I think he said). The Precision shits allover the -5's for response on the graph, and from his times, on the track too! The 32 is still 2.6 as well so these turbos are obviously a good thing!
Correct! and yes WOW! it has me thinking the EFR's are on their last chance... :yes:
I've already emailed him to find out exactly what version he has on the 32.
The 34 is running one also, however he likes the one on the 32 better.
One thing he did say to me was to buy bigger than I think I'll need and I won't be disappointed, they are that good.
I would choose a Precision over an EFR any day. . .too much hype with the BW's. . .too many results to look away from Precision. . .sorry, but a 2-year wait on an EFR is ridiculous. . .
bri73y.. .do you have a chart for that r32 running the 6766? I'm running this on my FD. . .sounds too good to be true that it would shit on the -5's. . .
No sorry, it's not my car, although it has lived in my garage for a while previously. Damn should've stolen bits off it when I had a chance.... :whistling:
Any email back? The one on the 34 did look a little bigger but by how much I couldn't say. I'd love to know!
What do you think you will order for your car John? 6466?
Hey Joe, or anyone for that matter..
Is there any evidence that the Full Race Manifold is worth the cost vs 6boost & ETM etc being about double the $ ??
Will wait and see how Piggaz's turns out, as I also have a 2.8, been running a TO4Z for a couple of years on stainless china manifold, time to get with the times, with a good manifold and probably a Precision..
wouldn't the one Jez is running, with 30+ psi on a 2.8L with cams etc see 450-500rwkw ? with awesome responce .
Edited by tricstar
Is there any evidence that the Full Manifold is worth the cost vs 6boost & ETM etc being about double the $ ??
Will wait and see how Piggaz's turns out, as I also have a 2.8, been running a TO4Z for a couple of years on stainless china manifold, time to get with the times, with a 6boost and unplumbing the gate.
Fixed, no need for new turbo :)
Well it made 436 on a 2.3 SR with 24-25 lbs of boost on the same dyno as i made 425 with -5's. It beat my setup low end and pipped me up top. I'd love to see what it would make with 30 psi!
If the 6466 is too big just rip it off and drop back 1 size. Little touch up and away we go!
Honestly mate don't know if the full race is better or not. Would need to do some back to back testing which would be a real pain in the ass as you would need to plumb up 2 different sets of gates.
If I had my time again I would probably just bought a 6 boost one for reasons such as
1. Cheaper
2. Quicker to obtain (each fullrace manifold is made On order)
3. If it cracked or failed in anyway would be easier for warranty
4. The full race is a bit of a nightmare plumbing wise.
Though I do like how the manifold looks and how it makes the turbo sit towards the front of the car.
I also had to cut a bit of the re enforcement out of my bonnet to fit the Massive frame of the BW
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
