Being built by advanced and tuned by JEM I doubt anyone will question the numbers.
Interesting about the breather being normal for that power level, not something I expected.
Because u dont normally see it.
Out of site out of mind :)
It's the catch can breather.
For anyone possibly doubting the numbers, it ran 10.7@147mph at WSID with 490rwk. Next time out with 536rwk should do 150mph+
The car is also on the Motive 16 Drag battle DVD.
I'm questioning the numbers! That was 10.2@147 not 10.7! :)
This was the first thing I noticed as well
Seems odd to keep pulling those numbers with that happening
It was mainly in relation to that...
Yeah I wasn't sure if it was 10.7 or 10.2 :D
Edited by SRS13
I might be selling my 5858 BB turbo. Brand new, box hasn't even been opened!! After $1450 for it.
Thinking about going bigger (6262) as the engine being built will need a bigger turbo!
If interested PM me.
Edited by SRS13
Finally got some numbers but its not done yet,
On the New motor, with the 6262 .84 TS BB CEA.
Run-in tune (super safe) verylow/negative timing, 9-10 psi. 210-220 rwkw.
Turbo is super responsive and perky even with the timing so low, I noticed instantly its very throttle responsive, its very possible my intake setup helps in this regard. But the way it moves the air so quickly I have a good feeling this setup will be pretty decent on the 30/25 with vct!
One noticable characteristic.. the turbo seems very loud. even on low boost. however i am moving from lowmount to high mount during this build, so that might be why i think that.
will be doing real tuning next week if all continues well. Will post numbers as promised when its done. Unfortunently still running hte PFC and Tomei Z32 as no one has purchased the gear yet.
-dale
Edited by SilverECR33
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
