i have seen dyno sheets floating around which are probably in this post somewhere anyway - which show the difference in the response between, 6266, 6466,6766 being about 500rpm on a 3.4L ...
I have even emailed precision directly who have confirmed that it would be about 300-500rpm on a 3L
Thanks. Have seen it but not sure on that one. I think the 6262 is the one.
Yeah just give it a ago they are pretty interchangable apparently.
I went for the 6466 as I figure if worst case it was 600-700 difference in response from the 62-64 - something i doubt im really going to notice when its on an engine which will snap the rpm needle within a matter of seconds anyway - which is worth it considering the top end gains!
Is anyone running a 6266? How much lag are we talking about between the 6262 and the 6266? Can't decide on what to go for. If the RPM difference is negligble i'd be more inclined to go with the 6266 for the potential to make more power at a later date. (Both turbos with 0.84 Twin scroll)
Looking to make 400kw on a RB26 with all the basic mods. Will a 6262 make that power on 98pump fuel (say no more than 25psi)? I've seen that SimonR32 made 420 but that was on flexfuel.
Edited by RRP1
I actually made 450kw and trust me there is plenty more in it but I ran out of fuel pump.
I wouldnt be suprised to see another 30-40kw if I ran 25psi but as you said that is on e85.
6262 is a nice balance for decent power and not too much lag. I was tossing up between it and the 6266 and went the smaller. I think I made the right decision
Edited by SimonR32
no probs....i dont think there will be too much difference to be honest but i cant find the wheel sizes for the 6266
6262 is as below tho
Compressor-
Wheel Inducer: 62mm
Wheel Exducer: 82mm
Turbine Wheel -
Wheel Inducer: 72mm
Wheel Exducer: 62mm
i think i did read that the exducer of the 66 was slightly bigger but dont quote me
PTE 6466 - for anyone looking at this turbo.
Compressor Wheel 2.535" (64.39mm) inducer / 3.410" (86.61mm) exducer
Turbine Wheel 2.920" (74.17mm) inducer / 2.600" (66.00mm) exduce
HKS T04Z:
Compressor Wheel:
T04R/T04Z, Inducer 66.7mm, Exducer 84mm.
Turbine:
T04 P trim, Inducer 74.2mm, Exducer 64.6mm
Garrett GT3540R/GT3582R/GT35R:
Compressor Wheel:
56 trim GT40, Inducer 61.2mm, Exducer 82mm.
Turbine:
84 trim GT35, Inducer 68mm, Exducer 62mm,
for comparison..
Alot of guys are running the 6466 in favour of the 6266 in the states and report no change in spool/response but more power up top.. Would like to see some results on RB26 though.
Edited by RRP1
So how do people reckon a PT6466 would compare with a Garrett T04Z in overall performance? Would you be able to use the Precision in the Garrett's place and expect to make similar (or better) power on pump gas on a suitably built engine?
HKS T04Z:
Compressor Wheel:
Turbine:
Compressor Wheel:
Turbine:
for comparison..
6466 only comes in ball bearing tho which is all good but cant justify the extra cash for it
i dont think you can go wrong the PTE to be honest
Should make plenty more power without being too much laggier from what I have seen
Thats interesting, I'd have hoped for it to be at least as responsive!
Well my 6262 is better than my old T04Z but not the miracle that some would lead you to believe. The 6466 is a fair wack bigger (195hp rated), I doubt you would be getting that for nothing :)
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
