I've ordered my 6266 today, will go on a fully built 26
Super keen to see how this goes, not just for outright numbers but response and midrange
Should be an animal on eflex, haven't decided on cams prob end up going poncams...
Edited by SiR_RB
:woot: I would love to know what your definition of "outright numbers" are if you call 6266 for response and midrange versus big power!! I assume given you didn't go 6262 or equivalent you intend on pushing the turbo reasonably hard?
My aim is for mid 400kw on I'm guessing maybe 24-26psi or so
Won't be pushing every last kw out of this setup just yet, gotta make do with my current fuel setup and lack of money after this build lol
Also gonna be using a GFB 50mm gate as my mate works there and can get them for a good price, undecided on manifolds but obviously 6boobs seems like the way to go....
Keep you guys posted with updates
I may have a slight rear seal leak already. somehow, and the cars still on run in, running spring pressure (seeing 10psi). turbs was primed properly and always warmed up/down. still not 100% yet, but if it is.. damn shame and will have precision on the phone askin for answers.
I got mine from real street performance in Florida USA
Had a slight delay with the rear housing but it left today should be here in 3-4days
coming in over 1k? they quote me about $150 for postage which blows
I bought most of my engine gear off these guys, $150 for postage from them is fair. It ships mega quick.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
