Good ? on comp Ratio as it hasnt been tested since the built to be honest it has sat in the shed for 3 years with doing nothing. It comes out sometimes & getz fair up it down this road I know quite well. Head work ported Polished supertech vavles. It made 450KW with the HKS To4Z strapped to the side of it with race Fuel 23psi.
Twin scroll ryan 4inch inlet & 3inch out from memory. Has 3.5 inch exhaust but not that thats going to matter its coming straight out of gate so should sound the goods lol.
Cool can't wait to see your results trying to decide whether the 6766 is going to be too small for my new 3.2L thats in the build ATM ;)
1000 flywheel hp or as close as I can't get with good spool
What fuel? If on E85 then the Precision PT6466 seems to be the man for shooting in that area - basically every result I've seen for that turbo have been exceptional "for what it is". PT6766 CEA will do it and with a bit of change and a bit more lag, Forced Performance GT3794HTA is not a Precision turbo but I reckon from what I've seen makes me think they have a compressor map more suited to RBs (and 2JZs) - a little wider flow in the 30-40psi boost range (the Precisions definitely need more boost to make these power levels), and they sound awesome. A SLIGHT (ie 100 or so rpm) bit more lag than the two Precision turbos though.
Going on a roller (dyno dynamics) tomorrow... Ewwww :(
I'll try and get a run on current tune with same fueling to see roller vs hubber before we play with boost
Awesome :)
+1 actually, I've been treating the difference between these two as ~11% (so 600hp @ hubs = 534whp/399rwkw) so will be interesting to see how close this is.
There used to be a fairly well proven 7-8% difference between the hub dyno and a roller, we could repeat it every time.
The hub dyno we use has now been updated with new software and corrections (the 600hp run was done with this) and they are meant to read similar now.
Ahh cool, good to know - I had partly based that number off what SAU people insisted when comparing hub dynos and otherwise but have been starting to get suspicious after seeing trap speeds of cars run on DD being much closer to cars with similar Dynapack numbers (ie, my own) but had used that partly because of avoiding angsty Aussies complaining about inflated numbers :)
Keen to hear the results anyway, especially when you nudge the boost up!
Well that was a bit of a fail, there is an issue with the dyno and even with 4wd set to 50/50 torque split the thing was doing burnouts as soon as it came on boost...
Ended up going 560hp but started spinning at 550hp and pretty much flat lined from there. Would have been well over 600awhp on 24psi if it had traction :)
Edited by SimonR32
put 20 fat kids in the back! dont comment until we have results!!! :P
this is still with the 6262 yeah simon?
No access to 20 fat kids so it'll have to do. The power was almost ramping vertically when it started spinning and then hovered around 550awhp from 5500-8500.
Yeah 6262 T4 divided 0.8 rear
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
