LOL Simon, that car is fast. Sky is also blue, but I just wanted to say it.
How do you get your freaking helmet to fit? Im only 180cm and a helmet like yours in my S14 does nothing but trade colour schemes with my hood lining.
Is the Bride mounted super low or your shorter than me or what? It shits me to tears, I need to lay my seat back heaps and slide around like a moron at the track lol
haha
Response wise the 6262 really impressed me over the weekend. Did lots of roll ons from 60km/hr (just under 4000rpm in 2nd gear) and every time it was cracking gate almost instantly on 100% throttle application.
Check out this run with an XR6 Turbo that runs a 11.9 at 120mph at the drags. I hit the throttle at the big bollards and it is straight on gate (24psi)
Is it me or are these Precision turbo's very quiet on song? Every video I have seen they are quiet as!
Bulldog run Simon. Congrats :D
The mid frames hardly make any noise, when you're cruising they make a multi-pitched noise though, you can notice it at night.
The larger frames like my 7175 "almost" sounds like a T51R.
What power was the r32 it making in this video?
It was making 600hp on a hub dyno, we tried to tune it on a roller with about 4psi more boost but it just wheelspun at 560rwhp,
Best guess would be 650hp at the wheels
Edited by SimonR32
Here's an update for the RB26 VN at the track. Still a bit off its potential on this power (910hp at the wheels on 25 psi), but it's getting there! Weighs 3315lb with driver, has steel, glass and a heavy interior.
I'm sure you'll enjoy the sound.
Would weigh 3314lb after losing that side skirt at the start.
Amazing machine
Here is an insane result for an RB26, I can't get my head around the spool and power this thing has made - a mild built (no porting, not extreme cams) RB26 with nearly 500kw @ hubs/665hp @ hubs with excellent spool on a PT6266 BB:
Thread:
http://www.gtr.co.uk/forum/166866-nats-r32-gtr-3.html#post1762728
Raises some eyebrows to say the least.
Things to consider, it's on SAE correction on old software so I would say it's around 600rwhp on a roller (but that's on normal fuel not E85)
You have to wonder how long the ramp rate is, 350hp at 4000rpm is about double what I would be expecting from that turbo
Edited by SimonR32
They are certainly capable of pushing beyond their power rating, but I've seen some figures floating around with way too much GST on them.
If they aren't done on an engine dyno or backed up on a track, they are just that...numbers.
No doubt, mine isn't getting pushed at all and it's starting to get right up there power vs power rating wise.
I just find it hard to imagine a larger turbo on basically the same motor set up as mine and Jez's is making almost double the power at 4000rpm and a huge extra wack of hp top end all while using 99 Octane fuel not E85
If I thought that graph was genuine and repeatable I would have already sent an email requesting an invoice for the purchase :)
Edited by SimonR32
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
