No doubt, mine isn't getting pushed at all and it's starting to get right up there power vs power rating wise.
I just find it hard to imagine a larger turbo on basically the same motor set up as mine and Jez's is making almost double the power at 4000rpm and a huge extra wack of hp top end... All while being on 99 octane fuel vs Jez and myself on E85
If I thought that graph was genuine and repeatable I would have already sent an email requesting an invoice for the purchase :)
Any thoughts on how it is possible? I agree, it seems unbelieveable - but there has to be an explanation! SAE doesn't inflate numbers THAT much unless the temp sensor is somewhere silly, perhaps.
Might have to check more MGT dyno results to see if they have other numbers which seem too good to be true - they are meant to be a reputable outfit.
<edit> I think I have found a trend :(http://www.gtr.co.uk/forum/176121-high-power-rb25s-mapped.html
Lol you are everywhere when it comes to turbo results :P
Probably wont be able to get much help here but what would you guys recommend for a n1 motor with vcam?
6262 .84 twin scroll seems to be the go for a 26 but with vcam would the 6266 be the better choice with a bigger rear (1.0+).
Car sees a little track mainly for street though and will be run on e85. Ideally I'd want 450awkw+
i rekon a 6266 .84 divided rear would be choice
I got that same turbo on my built 26, still have standard cams, e85 etc getting tuned Friday so I can post up a graph then, will be good to compare to all the 6262 graphs getting around
Edited by SiR_RB
Update guys, The Old girl made 350kw 15 psi 430kw 24psi, 30psi made 436kw @ 6000rpm ignition prob the splitfires arent coping plus Im thinking the exhaust maybe holding it back 3.5 inch dump pipe 3.0 inch exhaust maybe to much back pressure we will check & see whats going on. Should be up around 500 plus in my eyes gate is vented straight out with screamer pipe. Need to iron out the little bugs then hopfully see some decent numbers.
Very nice mate!
When does this all start to happen, RPM wise?
I would have to agree that 3" is too small for any part of the exhaust when reaching for those power limits.. 500kw is basically 4" TBE zone.
Didn't it make good power on pump gas? If it can made 450kw on straight pump gas then it should be able to make a fair bit more than that on E85... if it isn't then the cause is more likely to be ignition or something along those lines.
to put it straight Lithium, The 450kw was on race fuel at autosalon with to4z .82 rear 24psi, was making 430 on pump98. Just its really bugging me that it seems stuck at 400 plus. In all Honesty it should crack 500 plus @30psi one would think engine sounds great. Did a comp test evrything is good 134,134,134,135,137,134. Thinking either LS2 coils or okada what your thoughts about the situation?
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
