That's strange, can you show us a video?
I thought it was a bit strange. Its turning but you can easily stop it by hand. I've had the oil restrictor out of it to tap the oil feed fitting thread a bit deeper but I can't see that causing any issues. I'll take a video next time the car is running. It's still about 98% complete atm
  • 3 weeks later...
Here's the guts of a stuffed 6262 if anyone was interested in having a look. I can't understand why there isn't rebuild kits available for them as they are so simple to work on. The bearing assembly isn't even a press fit so you could do seals without having to spend a fortune. Would only be a matter of having the assembly rebalanced again
Edited by PSI086
I've had a few people quiz me about this car, maybe they didn't realise a 6466 is rated to 900hp :)
Yep people seem to treat this kind of thing as too good to be true, here in NZ it seems that largely people are uninterested or unconvinced at the new turbo choices from the likes of Precision, BW, Forced Performance - the Garrett GTX are getting some popularity, just because it's Garrett I guess. A bit of a shame really, the 6466 is just an amazing turbo from all accounts!
Wanting to see the dyno plot for me is so I can see how it comes on boost on an RB, most other countries stopped using T04Zs YEARS ago while NZ (and Oz even?) are still playing with them - given we're some of the bigger RB modifiers it means that there are lots of results around for them being a single turbo of choice, I'd love to see how the 6466 compares to a T04Z in terms of 'coming alive'.
Looking into the 6266 for a built rb30/25. Whats everyone's thoughts? looking for around the 600rwhp mark in an R33. anyone has dealings with both the Dual Bearing & Journal? Are they work the extra $$$
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
