That's strange, can you show us a video?
I thought it was a bit strange. Its turning but you can easily stop it by hand. I've had the oil restrictor out of it to tap the oil feed fitting thread a bit deeper but I can't see that causing any issues. I'll take a video next time the car is running. It's still about 98% complete atm
  • 3 weeks later...
Here's the guts of a stuffed 6262 if anyone was interested in having a look. I can't understand why there isn't rebuild kits available for them as they are so simple to work on. The bearing assembly isn't even a press fit so you could do seals without having to spend a fortune. Would only be a matter of having the assembly rebalanced again
Edited by PSI086
I've had a few people quiz me about this car, maybe they didn't realise a 6466 is rated to 900hp :)
Yep people seem to treat this kind of thing as too good to be true, here in NZ it seems that largely people are uninterested or unconvinced at the new turbo choices from the likes of Precision, BW, Forced Performance - the Garrett GTX are getting some popularity, just because it's Garrett I guess. A bit of a shame really, the 6466 is just an amazing turbo from all accounts!
Wanting to see the dyno plot for me is so I can see how it comes on boost on an RB, most other countries stopped using T04Zs YEARS ago while NZ (and Oz even?) are still playing with them - given we're some of the bigger RB modifiers it means that there are lots of results around for them being a single turbo of choice, I'd love to see how the 6466 compares to a T04Z in terms of 'coming alive'.
Looking into the 6266 for a built rb30/25. Whats everyone's thoughts? looking for around the 600rwhp mark in an R33. anyone has dealings with both the Dual Bearing & Journal? Are they work the extra $$$
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
