Interesting to note the SR22VET is superior on all accounts. Its over half a litre smaller.
It goes to show that cylinder head technology pays out a lot more than cubes.
I think there is more to it than that - compare it with similar sized smaller and "higher performance" wheels to an HKS T04Z, and even the larger (and older tech) HKS T51R Kai on an RB28 running pump gas: kaibb%26%2Bto4z%2Bpower.jpg
Going by that, a T04Z spools better than both turbos - and a T51R Kai is not far off them at all.
Regardless, yeah - SR22VET is way up there in terms of efficiency, while RBs are not so much... by todays standards.
The head on Ninos's engine is top shelf and costs more $$ than what most people are prepared to pay, hence a nice result. That and his engine is a result of endless testing by Advance Motor mechanics and associated companies/people.
Its is all about combo rather than bolting on an "awesome" turbo and expecting to get the same results as others.
Glad to see we agree.
I was not implying the VET head alone is all the difference, but the technology implemented in that cylinder head is clearly a winner. That means both the factory VET side of things and the work the said firms have put towards it.
Lith when I look at those graphs I still see that the RB28 you posted is behind. I typically look for the point where the incline starts to nose over and I consider that to be the point where the motor has hit its threshold. The said VET is hitting that point at 4,700 whereas the RB28 you posted is 5100 on one of the turbos and 5500 on the other.
Obviously there are only hundreds of RPM in it for vastly older tech turbos but I think it notable to consider the big difference in capacity between the two motors. Plus, my comments were actually specific to the two results shown rather than general. I am more than confident that we can find a VET result which is shadowed by an RB.
Agree Ninos engine is sensational and I'm expecting similar results with mine but isn't that RB28 on 93 octane? If so then not really a like for like comparison or even comparable IMO.
Those turbos on 93 octane are not going to perform anywhere there capability on any engine let alone that one.
Edited by SRS13
Yeah definitely, the thing that really does impress me about it is that power is huge for a 64mm compressor on pump gas - I reckon. I'm not sold on the power delivery, though - I think there are competitors which would do that with better delivery at this stage.
Went out again last night with new suspension, looking forward to a prepped track and getting the car to hook up. Ran a PB on lower trap speed and a slower 60ft so that's a good start! 2730lb, only thing removed was the passenger seat and side pipe fitted. Looking forward to get this thing to hook up so we can tap out the 7175!
Different angle with incar
Edited by PJ.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
