lol, im keen to try a 6766, but even with the modern tech, i have a funny feeling it wont outperform/or be as good as my old gt4294 setup
have to wait for this 6870 maybe. Pity Pt wont make custom turbos a 6775 would work well...
Outperform/be as good as is a relative term. The cool thing about a lot of these turbos is the size difference - I almost had to eat my hat (thanks Nytsky) its pretty cool that a 64mm/66mm turbo can make the same kind of power as a 70mm/71mm hero turbo of the previous decade... there is no that that is not giong to have a really noticeable difference in the real world. Aside from "that sound" I'd much rather have that response of the 6466 and the same power as the T51R Kai, quite keen to see results from FP's take on the 6466 which has now been released - they are clearly taking aim at the Precision unit and their turbos in that size range are often quite rowdy, if they can do something to rival the 6466 in all relevant ways then that would rule :D
Precision already do a PT6768, and FP do a "6868" (Super 94HTA) using an aggressive (flow versus size) turbine design so there is already something on the market for that kind of target, but yeah - I think decent built RBs probably need something with more turbine than the likes of the 6766, depending on what you are looking for.
yes it is definitly a relative term Lith. yeh the 68 turbine is a q trim wheel, looks like when they updated from the 65 to the 66, it probally made it
a little redundant though maybe?.
i was thinking in auto Rb30 terms., with the extra load a bigger turbine would keep the egt in check and make the motor a whole lot happier in the tune up ,the 6766 is no
doubt always going to choke on a Rb30 in the turbine section and not the compressor side with 93lb of flow id guess.
although some of the 2j supra results are outstanding..
Can't wait for this 6870 deal..
cheers
darren
Edited by jet_r31
Hi Dave
A long time coming but here is the difference from the T78 and the PT6262 and it drive like a different car, clutch is easy with a bit of power down low :)
Brown = new tune
Blue = old tune
so it takes 23psi to make 333kws thought it would be running close to 350-360kws at that boost pressure is yours twin scroll? Dave hurry and chuck the results for the RB25 on twinscroll.
Still awaiting the retune results on my 6466 on my 25/30 motor. Hopefully some decent numbers
Thought I'd update this thread to for those not following my build.
Got mine tuned Friday :My 6466 went 630hp on 29psi but was lifting the head. Ended up winding it back to 451hp on 15psi for now till we can get in there and sus out the problem. Car already had ARP studs. Dyno graphs to follow
Expected 350-360 as well, said the exhaust is very restrictive , having a custom done.
It was also having a fuel problem, not sure if this made any difference??
They said that tuning for response you loose some top end power ??
New to this so I can only take the word of a professional tuner.
If you could have driven this car before and now you would be like me, happy :)
Pete,
I'm just finishing off a carbon fibre custom catch can setup, got mines baffles and -12AN speedflow lines to help everything breath a bit better.
Saying that it's almost finished and once all assembled will be dropped off for head removal and the last few bits going in.
I'll update this thread with results as soon as it hits the rollers.
First half of the catch can setup for those interested in pics
Cheers Noy
Well had the exhaust done, did not pick up much power but it helped where I wanted it, response.
since I changed the Turbo,Cams and Exhaust the car has gone from a pig to drive to being fun, enough up top and good bottom response,street drive :)
Here is the latest Dyno
New Dyno 345.4 KW
Red = Boost off
Blue = Low Boost
Orange = High Boost
Old T78 = 337.9KW
Pete,
Cheers Noy
Hi Noy
Like to see the results when you are finished, as for me I am done with the mods, the car is driving very well for a DD and that is what I wanted . I have a 350GT Skyline (Jap Import), I put APS Twin Turbo system on it and with the extra torque it made the R34GTR seem crappy and it was a "thing" to drive BUT all good now :)
One thing left to do I am putting 18" Advan RS-D , machine lip/ gloss black spokes, have a look on their site and tell me what you think
Pete
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
