Finally had the tune...
So stoked for the little rb25 with 647 hp @ wheels on 28psi.
It actually comes on the converter 200rpm sooner than the to4z.
I need cooler plugs and a bigger wastegate and it should make 700hp pretty easy as the 647 was with early shut off cos of break down and boost creep. image_11.jpg
  • Like 2
I am about to go down the 6262 (0.63 rear) path on my rb25. I'm chasing 280kw ish low boost and 320 - 350kw high boost. Engine is built and has supporting mods. Just unsure as to what gate pressure I should run for low boost. Fuel will be 98. Was thinking between 16-18psi low and 20-22psi high.
Small rear housing plus 98 isn't a very good idea imo.. I made 288kw on a GTX 3071 on 98. Id look at something smaller than a 6262 for 280kw.
That kinda power can be had on a stock lowmount position kinda turbo.
Big $$$ changing manifolds and plumbing up EWG etc for a laggy 280kw - 350kw IMO.
Edited by Mick_o
I drove a supra locally here that makes 350kw @ 16psi on a gt3582 with a 0.63 housing on 98. Looking to make 320kw+ in the high boost region, so it must be able to get there if the 3L can do it without it choking. If I have to run a little more boost to get there I will. Just trying to work out what spring I should be running in the gate for low boost to roughly get in the 280kw area.
5858 0.84
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
