Opinions on a 6466 w/ .84 TS on a built 2.6 with 272/272 10.2mm lift cams?
I have poured through this thread, and as such was leaning towards the 6262 or even considered the 6062 Gen2 thats just been released - but my engine builder is telling me the 6466 is 100% the go
I trust the workshop, but just want to double check other's results; dont want something that comes on at 5k or later.. id rather it come on hard at 4.2-4.5k rpm
Its concerning seeing people say a 6466 outflows a T51R
A rb30 usually adds about 500rpm response all things equal... My cams are bigger than yours, so you could possibly base it off that. I'm using a 1.0 divided housing.
I don't think it will be bad, certainly better than a T51R in response, even if it does flow more top end. Thats the beauty of new technology.
If you're worried about response though your are probably better off with a smaller turbo, unless you have a power figure you definitely want. Take into account the 6466 is a 600awkw turbo
Depends on car use, I'd be giving a 6062 a go if your stuck between the 6262 and 6466 for a decision. It should sit right in the middle in response and power :)
I try and do everything with my car from tight sprints, circuit work,1000m drags and powercruise etc. and the 6262 is right in the sweet spot of power and response. I actually turn it down 140hp for everything apart from powercruise and drags because it's more than enough. What do you want from your car?
A 6466 is going to be responsive for its size but it's getting towards drag car only power band on a 2.6L, if that's what you want then go for it but your never going to keep up with the Jones's.
What would you guys recommend for. Street drag VL, auto re401a
Forged Rb30 NEO head
270 9.2mm cams
Plenum etc etc 3k stall
Currently running gt35 .82 internal gate
22psi 422hp but out of injectors
98ron
I was looking at the 6466
6466 1.0 divided.
I make 433awkw on 22psi, 98
100kw more on e85
Should be plenty to run 9's
It's been a while but here is my Dyno sheet from build
Rb26 precision 6262 at 19 psi.
Car is running good other than its smoking from turbo.
Anybody here using restrictors? I just put a .030 restrictor and stopped smoking but not sure if I should drive it.(n1 pump)
EC990DBB-75E3-4453-89C1-EC9B0C5E4339_zps
Thanks for the quick reply guys. Haven't removed the factory restrictor. I'm running a -4an feed line and a -10 am drain line. Drain line is pretty straight down with now kinks. I also did a leak down test and compression test on the engine. Got 128 psi on all 6 cyl.(running 8:3:1 CR) and dry leak down test was 10% on al 6 but #1 13%. Not sure what other options I have
I'm getting 45psi. Pressure at 2.5-3krpms and over 60 psi from 4k up
Edited by silvianc
Is that America?
because that is epic power in Australia for that boost
Lol yeah. I'm in the U.S.
Setup made
390hp@9psi
450@11psi
560@15psi
611@19psi
This is on a 2.6, 87mm pistons and Tomei type B cams, t4 .84 divided housing and limiter on 8400 Rpms but u can see dyno sheet actually was 7.8k Rpms
https://m.facebook.com/story.php?story_fbid=773329676088103&id=142284982525912&_rdr
Our horses are angrier
Hell yeah. I'm in the USA too. Here I am thinking of seeing 550 whp on pumpgas and I'm at sea level and I'm on a stroker motor. Heck I may see 650 whp on pump after seeing this !
You'll probably see 550 Australian horses if you've been looking at our graphs. More if in USA
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
