I am near completing fitting out the front facing plenum. The fmic is in and piped up, that was quite easy, as was most things after, as Darrin put it, a few drinks.
Now the original procedure was via stuff from Skylines, and the fuse boxes in the 33s is different to the Stagea, Thats a bugger caus you cant turn the T/B 180 degrees not even without a spacer. So I got all the bits in except the BOV. This was shown as being on the cold side of the IC. This means a massive piece of 30mm tube to get back to the inlet if you are not atmospheric BOVing.
Then thanks to KiwiRS4T(Bob) who is researching the same subject, I saw a BOV, vented back to the OEM inlet pipe, on the HOT side of the front mount. Now is this wise? I need some feedback as I am worried that the unloaded gasses may be too hot.
Help!
https://www.sau.com.au/forums/topic/314318-bov-relocation/
Help!
I was always under the impression that the closer the BOV is to the throttle body on the cold side the more efficient it works, as it would release pressure from the point furthest away from the turbo...
its not uncommon to have a piece of pipe running from one side of the engine bay to the other as a return, as coming from s15's that's how they were stock...
my 2 cents tho...
https://www.sau.com.au/forums/topic/314318-bov-relocation/#findComment-5157843
I run a front facing plenum with BOV in the hot side plumbed back to intake. Works fine, shouldnt really matter. Heres a photo to hopefully help you out, I know its not a stagea but may still be helpful
PM me if you want more photos
https://www.sau.com.au/forums/topic/314318-bov-relocation/#findComment-5157876
Im interested to see if you guys notice a loss of response with going the forward facing plenum, im contemplating doing it on my R34, but i dont want to lose any response or mid range, and being they have shorter inlet i would assume you would lose some?
https://www.sau.com.au/forums/topic/314318-bov-relocation/#findComment-5158232
I guess Duncan would be the best to talk to. Or go to Skylines and look up Front Facing Plenums. There is a fair bit of info there. A lot of 33 drivers have done it.
Also if the runners were longer it would be better low down, but there is not much room. I think it will be better up top.
Edited by 66yostagea
https://www.sau.com.au/forums/topic/314318-bov-relocation/#findComment-5158403
I presume you mean off boost but I don't expect it to make any difference. On boost I thought the point was to reduce the length of piping and so reduce lag?!
https://www.sau.com.au/forums/topic/314318-bov-relocation/#findComment-5158551
my particular plenum has quite long runners for greddy style....but I can't make any comment about response because I did the 3l block at the same time....
considered running no bov like me? it makes a very childish noise which makes me giggle :P
https://www.sau.com.au/forums/topic/314318-bov-relocation/#findComment-5159982
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
