ill definelty try that, i was playing around with different settings but i dont think i used that one will post up pics when i try it :)
Hmm, the Exif data says that the flash was fired for that first shot.
If you're using Firefox, try this program and take notes of what settings people are using for various photos: https://addons.mozilla.org/en-US/firefox/addon/5673. It doesn't work on all photos, but it should help you out.
  • Replies 200
The last shot is great. Would love to see a bigger pic of it.
Agree with Sid - would love to see bigger versions.
CPL you say? Gotta check that out, being car obsessed and all.
CPL = Circular Polarising Filter
And I can't comment if it would actually make car shots better
IMO awesome car shots DO have reflections.
Trick is to not have crappy stuff IN the reflections lol
Facebook l Redbubble l Twitter l
© Copyright All rights reserved Aaron Radford 2010
Here is a Larger version
Strobist Setup
Canon 430exII @ 1/2 power on light stand approx 6ft camera right shooting down onto models back.
Erm... CPL DOES cut out the reflections.
As you rotate it lets in light from different angles, so you can twist to let some reflections in, and glare out, or twist to remove reflections and let glare in. It Imagine all the light coming to you is made up of 3 sine waves moving sideways like slinkys. one is horizontal, one is vertical, one is 45" between. The CPL removes the light from ONE of these directions, changing as you rotate it. Wow I sound like professor frink! WHOOO HAveNNNNNN and the MOnkeys!!!
I'll post up an example when i get home. I have a few test shots from the same angle to show the difference. :/
This is how you can imagine it works - look at the second picture here: http://en.wikipedia.org/wiki/Polarizer
Basically lots of light coming from all directions - CPL cuts it out and only lets light from a certain direction come through. Rotating it changes this direction.
(direction might not be the best word here but you get the idea)
Back in April 2008 when I bought my first CPL I got it for better colours and cool looking sky's
Here are four sample pics I took (None of them have any PP done)
well the way I thought it worked was as glare being diffracted light and reflections being reflected light, and a polarizer will only permit light in one plane to enter the lens. So my assumption is that a CPL will remove glare, but will only remove the intensity of a reflection, but not completely.
if your polariser is letting in the reflection of a hot chick next to the car, that's a good reflection.
if your polariser is letting in the refection of extra light from the sun you don't want, that's glare!
You know what i mean anwyay :)
You need a little more exposure and post processing on that one. You didn't get anything but the highlights on the car. You're having trouble adjusting for brights to darks.
Try and equal your shot out by the EV reading on the camera compare night and point it at the car and see what the white equals and adjust for the best of both which should be in the middle of both.
Does that make sense to you?
EDIT
Looks like you shot in Auto mode as well, you need to shoot in M (manual) mode and mess around with your EV and Aperture. There are some nice guides here on the forums in this section. As well, you should never let your camera get to 1600 ISO unless it is something you just can not capture any other way. Get grain real bad at those levels.
Edited by AKW
Not sure what Ev is either, but on my Cannon (unsure about Nikons) Tv is Time Variable, meaning you can put it on a tripod and use a longer exposure. Also, try adjusting the white balance to get the colours right.
Btw, your car looks great now. Maybe some clear indicators and some work Meisters would look AWESOME on that thing! Possibly a front mount as well :)
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
