ill have roughly 35k to buy another car. I was just wondering what your opinions are on purchasing either a 33 GTR or and 34 GTT.
i currently have a s2 r33 slighly modified. i would assume that if i but a GTR i wouldnt need to modify it, whereas buying a 34gtt would be pretty stock. plus the disadvantage of not going sideways or drifting in the gtr
https://www.sau.com.au/forums/topic/31522-33gtr-or-34gtt/
  • Replies 65
Tough call that one. Everyones got their preferences and as far as looks are concerned that's something you've got to decide for yourself.
On "paper" both the R33 GTR and the R34 GTT put out the same power, so there's not a lot between them in the power department.
Most people are gonna say go the GTR because, well - it's a GTR! :(
With the GTR's you'll get what is considered a stronger engine, plus the ATTESSA torque split system. You'll also be getting an older car, with higher KM's and an older design. Personally I like the feel of the R34's - they seem much smaller than the R33 series, particularly inside. R34's have the more modern interior and the updated RB engines with improved torque output over earlier RB's. Handling, well my R34 handles pretty well but I've never driven an R33 GTR at speed so I can't really compare. Both cars have HICAS, LSD's, sway bars etc and both have 17inch alloys as standard.
If drifting is what you're wanting to do, then perhaps the RWD GTT would be the wiser choice.
Probably the best advice is to test drive both and see what you think! :)
Dave
https://www.sau.com.au/forums/topic/31522-33gtr-or-34gtt/#findComment-636377
Go the GTR, GTR's hold their value, $35k will get you a good one. Youll be able to resell it for what you paid for it. Plus GTRs are the ducks guts of all cars and what all GTS, GTT etc drivers dream of.
Plus power... stock GTR eats GTT's.
Plus Grip
Plus the 11 inches of front and rear rubber (265/40/17 fit on stock wheels)
Plus watching the tail hang out at will on a skid pan and then gathering it in by pressing the loud pedal
Plus street cred as in.. "What kinda *line* ya got" "OHHH so you dont have a GTR"
(Flame proof suit on)
https://www.sau.com.au/forums/topic/31522-33gtr-or-34gtt/#findComment-636389
^^^^^ hehe I knew you guys would say that ^^^^^
They're right though. The GTR has the street cred and the instant respect that the GTT lacks. Re-sale is always going to be better for the GTR. The GTT is an absolutely fantastic car in every way, but the GTR is better. I'd be happy to own either.
https://www.sau.com.au/forums/topic/31522-33gtr-or-34gtt/#findComment-636413
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
