No offence but that looks hideous and it's ability to flow well would be questionable.
In fact it came of an RB25DET pushing around 500rwhp
I couldnt give a shit what it looks like as long as it does its intended job.
Please justify 'questionable'?
Edited by RBceffy25
Lol no need to get pissed off about it, just said it looks terrible. It's not like you made it and im saying your work is shit.
Whether it made 500HP is irrelevant, you can do that on the stock plenum (for reference the Plazmaman one is rated at 1000HP worth of flow, in other words its "horsepower flow" is irrelavant.)
Its just a stock plenum that has been cut up and made into a foward facing plenum (as many people do) but he has changed the centre of it completely, however do you think it has been created to flow well and R&D put into it to flow as evenly as possible like a Plazmaman or Greddy one would? Just saying. It may flow well, it may not, hence my "questionable" comment.
Edited by PM-R33
All good mate no offence taken and I’m not shitty lol.
I understand everyone is entitled to their opinions however, it might pay to keep 'possibly' offensive comments to yourself. If I 'had' made it myself would you have made the same comment? Food for thought.
What I meant by "pushing around 500rwhp" is that the guy I bought it from obviously had no problems with it flowing well.
I love the pics of your engine bay and most of the way you have gone about your build but there are certain things I would have done differently. But I’m not about to start criticizing you for this.
It’s these differences that make owner/building and modifying such a personal thing and it’s what keeps forums and discussions such as these happening.
I chose to use this modified forward facing plenum as I am building/modifying on a very tight budget and cannot afford some of the more exotic items on the market. I have researched the factory modified forward facing plenum and it suits my intended build and purpose just fine especially from a budget conscious point-of-view.
I did not intend to compare my plenum to either the plazmaman or the greddy.
I was actually looking for info in regard to the benefits of using a much larger than standard throttle.
Any way back to the question.
I'm worried about the affects of turbulence as a result of interrupting laminar flow, So can anyone please tell me what the pro's and/or con's are of changing to a larger than standard throttle body?
Fair enough man. And no I would have not made the comment if you said you made it as I would not have wanted to offend your work, but since you said it was off ebay, hence I made the comment as I didn't think it mattered. All good.
Edited by PM-R33
do u need a retune once the plenum has been installed?
I did. I'm not sure if it's necessary ,but i went fom a return flow cooler with original plenum to a standard front mount with a forward facing plenum and i gained 13 rwhp up top.Made more power down low until 4100rpm.Then made less power until 5100rpm.After that it just pulled better nicely til 7200rpm where as before that it stopped rising in power at about 6700rpm.
well i received my plazmaman plenum today... WOW its a workmanship..
but all i have to say the greddy has over this is that it comes with all the little nuts and bolts to bolt it up...
saying that i would not ever trade this beauty in! amazing..
+1 for plazmaman!
Hey guys, I've got the Plasmaman plenum on my r33, came with the car when I bought it. Just took it for a dyno tune and my tuner said he doesn't like the Plasmaman plenums as they don't distribute air evenly to all cylinders. He then proceeded to show me the different colours of the plugs.
Anyone else come across this before regarding the Plasmaman plenum?
  • 2 months later...
  • 4 months later...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
