  • Replies 92
Thank god lol those Advanti's looked aids lol.
Just more to personal preference but i would have leant more towards a HKS GT3037s or GT3076 (Garrett) depending on brand preference off the standard exhaust manifold to get the same power but a bit less boost and also a ViPec or some ECU to delete the AFM but other than that nice build so far. Looking forward to track vids
  • 4 weeks later...
