OK so im inches away from buying a silvia....I love it in White and in Red....A bit more in red though but i love Sunroofs! The white one i looked at had a factory sunroof....the red one didnt....i called up 1 place today to see if they could fit a factory sunroof in and they said they couldnt because they didnt have the nessasary rig?
Does anyone know if i buy a factory sunroof are there places that will professionally install it or a cabable of installing it?
Iv already sourced all the nessasary parts for the sunroof for $400.....
Thoughts?
P.S. Oh and do you like silvia's in red or white better!
https://www.sau.com.au/forums/topic/316852-s15-silvia/
I think best idea is to wait until you find the one you want in the right colour and features you want such as sunroof etc.
Keep looking, there are plenty of S15's around.
White or Red? Well, it's up to you. Red cars go faster don't they? :)
https://www.sau.com.au/forums/topic/316852-s15-silvia/#findComment-5182703
I'd say cutting into the roof and installing a sunroof would be a costly process.
I'd personally buy the white one and respray it a unique red, rather than install an aftermarket sunroof on the red.
Then again, Nismoman's idea is even better.
https://www.sau.com.au/forums/topic/316852-s15-silvia/#findComment-5182706
Might sound weird but sun-roofs lessen the cars structural rigitity. Thats why Subaru only put them on Impreza WRX models and not Impreza STi :)
Sorry, thought I would share it. I like white Silvias :laugh:
sorry mate i dont understand, is the sunroof model is the roof height lower? And yes i intend to take it to a track....
https://www.sau.com.au/forums/topic/316852-s15-silvia/#findComment-5182935
Go the white one. With no kit and a nice set of wheels I think they look great. And as above a sunroof will give you less head room and once you put a helmet on you may find it a bit tight for space. It's crazy to cut a hole in a perfectly good roof.
We bought a 180sx with a manual sunroof because that actually provides more headspace as it does not have the motors and what not.
Wait until you find one with everything you want. It's alot easier.
https://www.sau.com.au/forums/topic/316852-s15-silvia/#findComment-5183350
it might only cost $400 to buy all the gear to put a sunroof in a car, but the cost of getting someone to professionally do it will cost much more than that. personally i wouldn't even think of putting a sunroof in a car that didn't already have 1, but then i'm not a big fan of sunnroofs anyway. they are more for the wank factor than anything and as people have said, they reduce headroom, which being tall, i like to have plenty off.
also sunroofs leak. it might not leak now, but eventually ALL sunroofs will leak and then you will get rust in the roof.
https://www.sau.com.au/forums/topic/316852-s15-silvia/#findComment-5187942
definately go white bro f**k red its gay lol
nothing wrong with red as such biggest issue i have with it is if it starts to fade you get yourself a pink car lol.
As has been said wait till you find one with everything you want or go for the one your most happy with otherwise
https://www.sau.com.au/forums/topic/316852-s15-silvia/#findComment-5189581
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
