You need to disable the blow off valve so that it cant release the air. You dont need any specific type of pipe, but a metal pipe with a pod will give the loudest dose. Theres a huge thread on a vl forum about the different shaped intake pipes and what type of noise they make BAHAHAHAHAHA!
Unfortunately though I dont know how to disable the blow off valve as I am new to skylines.
https://www.sau.com.au/forums/topic/316955-dose-pipe/#findComment-5184165
cool.. i kno how to disable the bov and add metal pipe... just not sure on what to do with the hoses once i remove the standard intake pipe..
any help would be useful...
https://www.sau.com.au/forums/topic/316955-dose-pipe/#findComment-5184198
Pff, everyone keeps repeating that crap about turbo chatter, 'dose' and compressor surge. People blow up their turbos by putting more boost into it, there still isn't any proof 'dose' has wrecked any turbos. Sure, in theory, engineering/mechanics wise, it should wear it more, but no more than a few % and far less than abusing it with high boost etc.
https://www.sau.com.au/forums/topic/316955-dose-pipe/#findComment-5184234
Sort of depends on how much damage your willing to accept then.
There should be a way to quantify exactly how much the reversion slows the wheel down, but it probably wouldnt mean much unless you could whack it on a dyno for back to back comparisons.
Cheers,
Mitch.
https://www.sau.com.au/forums/topic/316955-dose-pipe/#findComment-5184276
unbolt your stock BOV, trace it out on a rubber matt or plastic or aluminium, punch out 2x holes for the bolts, bolt back everything.. looks stock, flutters like a the sphincter of the universe :D
I did that when my stock BOV couldn't handle the boost but it got annoying so I replaced it with an aftermarket plumb back.
https://www.sau.com.au/forums/topic/316955-dose-pipe/#findComment-5184297
It's called search, use it:
Dose pipe: http://www.skylinesaustralia.com/forums/se...te=%2Bdose+pipe
Hektik flutter: http://www.skylinesaustralia.com/forums/se...Bhektik+flutter
VL uleh: http://www.skylinesaustralia.com/forums/se...lite=%2Bvl+uleh
Sick flutter: http://www.skylinesaustralia.com/forums/se...%2Bsick+flutter
Seriously, it aint hard. Justy type in an adjective describing what you want "sick, hektik, fully, awesome, mad" and then an adjective describing the noise "flutter, dose, pidgeon, zututu" and you will find a billion threads.
*Sigh*
Edited by PM-R33
https://www.sau.com.au/forums/topic/316955-dose-pipe/#findComment-5184302
One will be BOV return. Don't need this when dosing.
Other will be breather return from cam covers. Either get a catch-can or put a fitting in your metal intake pipe for that hose to push onto...
could i just leave it....????? technically it wouldnt be going any where anyway.. would it..???????
https://www.sau.com.au/forums/topic/316955-dose-pipe/#findComment-5184372
No because it will be a vacuum leak since from factory one side goes to the plenum the other into that intake pipe (not to mention if you just left it open oil could drip out onto the exhaust manifold and start a fire). So either block the right side off or get a catch can or plumb it into your new pipe.
Edited by PM-R33
https://www.sau.com.au/forums/topic/316955-dose-pipe/#findComment-5184380
*Sigh*
love your work...awesome.
on topic...why you would want to do such a thing is beyond me. Sorry Mr Cosgriff :)
Edited by Swiper the Fox
https://www.sau.com.au/forums/topic/316955-dose-pipe/#findComment-5184539
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
