  • Replies 51
so... anyone else here actually driven a NUR and a 33 GTS-t?
A NUR can punch out 300 without opening the engine or changing the turbos, a 33, for reliabilites sake, pretty much needs both. And cause someone will bring it up just to be a dick (Birds), I would suggest an oil cooler at least on the NUR... the injectors will be damn close to maxing too...
You'd be hard pressed finding a situation where the GTS-t beats the nur if they had the same power.
add 30k to it though and thats a different scenario. Really depends where you spend the money.
Quoted for truth!
I had driven one a few times (the same car).
Stock N1 Engine / N1 Turbo's (factory boost of 1.2 Bar = 17.4 PSi) / FMIC / Air Intake.
All was done was an APex'i Power FC / Full Turbo Back Exhaust and had adjustable Cam Gears.
Could have done without the Cam Gears, but was done when tuning.
306 kW's at the rear wheels, dyno'd at RE Customs.
lets stop this topic and turn it into a fail thread..... being led by the guy in this video
http://www.thatvideosite.com/video/we_just...oughwait_for_it
hell, as the owner of a R34 GTT I weighed up the options of going hiflow, getting everything done to the max, shooting for 270-300RWKW and when I did the calculations and cost I've realised the best way to get this done and be happy about it in the future is to buy a nice R33 GTR :whistling:
33 with 30k spent on it will blow the pants off a stock gtr, even a nur, in every way except for traction off the line. a 33 with 10k spent on it will beat a stock gtr.
ive ran an r33 gtr with an exhaust upgrade and beat it with just a cooler and an exhaust and arc air box.
so i dont quite see how spending 30k on a pos r33 will be intelligent besides 40k and u could have an r34 gtr or evo 8/9
there would be plenty of 33's getting round with that sort of money spent on them. hell there are probably 32's with that sort of money spent on them. it might not have happened all in 1 hit, but over time it adds up.
start with a dead stock car.
new wheels: lets say 2k
exhaust (decent brand): 1500
cooler (again, decent): 1k
so there's 4.5k on very basic mods
then lets say he blows a motor, or decides he wants more power and wants a built motor to take it
ecu + tune: 2 to 3k
injectors: 1k (rounded up a bit there)
turbo: i dunno, lets say 3k with all water and oil fittings and manifold
engine rebuild: honestly don't know, but i'd guess about 6k including everything
clutch: 500
diff: 2k
so there's 19k. then if he decides to give the car a respray, new bodykit and put in some racing seats or retrim everything, it wouldn't take much to eat up the other 11k.
sure he could've bought something else for that money, but this will more than like blow the doors off it, and what if he doesn't like the shape of the 34 or the evos. everyone has their own taste in cars.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
