  • Replies 72
My bf and I just bought a couple of voice activated walkie talkies today :P Should be fun to test them on the night.
I like Thursdays but maybe we can leave a little earlier? I'd rather be hanging out talking shit while eating at the end rater than at the start then having to hurry home.
oooo have you seen the the Scala Riders? Sort of 2-ways for bikes been wanting to get one that works with CB but had no luck, only one I can find are extended bluetooth but still go pretty far. Only downer is that the other rider has to have the same device. Earlier is good for me looking ot see you guys there!
I did use one of these devices a while ago with a friend but it cost over $200 and was pretty shitty quality of sound... The cb radios we got have earpieces that I would rather use under the helmet since it works pretty well. They are 1 watt and cost $170 from Dick Smith, they're working not bad so far :)
1watt :S wouldnt the distance on that be kinda shit?
Ah damn!
Car will be at the Paintless Dent Removal ppl.
It's ok, my Corolla with 4A-C POWAH! Will out run you all... :P
*Runs*
niceee!
Whoa....1 Watt?? I couldn't deal with that...sorry but I got a two 5W radio's and so does Phatboy and whenever we go on cruises were the only ones that communicate constantly and clearly cause everyone else with 1-2W radio's are always cutting out and is freaking annoying. Not shunning your choice or anything charli just saying my opinion :)
will come down for a bit.. up to my eyeballs in uni work atm so you'll all have to convince me to stay longer ;)
Bahaha so am I so if you don't stay your soft.....enough convincing? :happy:
cant wait guys... first time i get to take my car to a meet. so please dont be mean lol.. So glad to be a GTR owner =D
Hell yes! Not hating on the GTS-Ts and that but they're just not the same.
Ain't nothin' like Godzilla!
BTW I was a first timer two weeks ago and everyone was very kind.
scarface is right... I'll be hanging out the window again waving at everyone... and I'll be driving O.o lol
1 watt is fine!!! Jeez guys I'm only going to use the thing probably a few times a year... got the mounted howevermany watt radio in the hilux if I need it for something serious... which I don't... but we have it anyway...
Best use I get is sitting on the ring road wondering wtf is going on and being able to communicate with local truckies.
AGREEDD!!!! nothing beats the power of a godzilla (except a worked godzilla lol)
well just remembered i have tafe on thursday night =( guess ill have to miss the meet, but will definitely attend the next meet
Sad face. Will see you on Sunday though!
Tafe over a SAU Meet up?!
Just email your lecture and say you can't come to class.
but gtrs cant go sideways like we can :D
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
