what rates suggest for a r33 , whiteline front rear sway bars, 350hp, locked subframe, caster arms and 52mm piston monotube coil over.s
have been suggest 12/8 but thinking this abit firm?
i run 10/10 in my gts-t, suit my car setup. However i think 12/8 would be a good setup too, 10 in the rear is alittle stiff and tends to make the back end want to slide around abit. so a drop to 8 would help fix that.
That sounds really stiff.
I would hate to try and use those rates on our bumpy tracks
i think 8 at the front and 6 or 7 on the rear as a max....use sway bars to control roll.
Any stiffer than that would make the car impossible to stop or get power to the ground over bumps
i originally through it was going to be too stiff aswell but the car handles like its on rails. However i do have great controll over both my rebound and damper in my coilover.
+1. I had 10fr 8.5rr and it was too stiff.
How does it go under hard braking over bumps, or running over ripple strips etc.
no issue that car handles likes it on rails. Perth race track was recently resurface so its not bumpy at all and even riding or going over the ripple strips the car still holds traction
If you are running 16 x 6" re-treads then 4F & 2R woudl do the job. If running good road tyres then 4F & 2R may be ok. If you are running good quality shocks (what brand is the 52mm monotube shock) and semi slicks then ?????, if you are running slicks???? I think you are better of being softer then harder especially if its rwd.
Without knowing if the car is full weigh, lightened. GTS or GTR, tyres it is running. What sort of events etc then you cant really expect to get good feddback. If you can answer then someone may be able to help...lol not me but someone :rofl:
Without knowing if the car is full weigh, lightened. GTS or GTR, tyres it is running. What sort of events etc then you cant really expect to get good feddback. If you can answer then someone may be able to help...lol not me but someone :P
Thanks for the replies guys.
To make it abit clear
Im running ISC N1 coil over suspension, 17x9.5 inch rear tyres, 17x8 front tyres. Will be running both slicks and semi slicks.
Its a GTS25t R33 rb25det, full roll cage, around 300hp. Car is stripped interior. Has caster arms, locked hicas, locked subframe, lsd.
Assuming the tyre widths are proportional to rim widths then you will be enjoying bulk understeer.
So maybe fix that before getting too far into spring and shocks & buying tyres.
For my ten cents on the the rates if you are on R comps then the kg/mm number should be in the single digits and the front harder than the rear. Just don't get sucked into thinking that a bigger number = better. Doesn't necessarily work like that for springs.
Try 12/10 or 10/8 and see how you like it, spring are easy to change on coilovers and relatively cheap.
With my setup i find 10/10 to be good starting point but i can see the need in the future to upgrade the front spring rate to 12.
I have a very balance setup no understeer or oversteer.
When looking into my suspension setup it was extremmly hard to get any information on setup, and what parts to use and not use. I found that generally on sau people dont like big spring rate. Compare to what track car run in Japan and Europe.
I guess it depends what works for you and your setup.
Are you running stock swaybar? what is your allignment setup? (camber, castor, toe?)
Dont run 12/10....you have to admit you are in the minority for liking so much spring in a GTSt :(
Its as much about the quality of the shocks and its ability to control the spring. No offence to ISC N1s, just like many other shocks for the money would not handle such high spring rates well or or long without boiling the fluid in them...assumign they work with the rate in the first place.
I would personally work in the 8/6 range myself, max. Thats assuming you like a stiffly sprung car
Dont run 12/10....you have to admit you are in the minority for liking so much spring in a GTSt :)
i guess :D but i like it like that :)
i do agree that the quality of the shock is important, no idea what the ISC N1 are like and if they are only damper or rebound and damper adjustable.
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
