  • Replies 566
Updated list
Sellers:
Aggroman --> Sold to Mccready
GTRsean --> Sold to Ravenoak
Tonba --> Sold to a mate (please let me know details)
Black Beast has spot for sale - Deano1 to buy
Liz has spot for sale - Sell to myr332!?!?!?!?
Potential Buyers:
Deano1 - taking Black Beast spot
myr332
So looking at this, Liz is only one left with a spot for sale. So hopefully this can go to myr332.
LIZ - Can you please chime in or PM me and/or myr332 pretty please :D
ando, where did tonba say he was pulling out? i cant see any of his posts that say anything but showing up?
Liz we are full so we can do a refund. send me your mailing address and I'll organise a cheque. unless someone takes your spot first
Duncan, i think Liz has/should be selling position to myr332. If not resolved by tomorrow then refund Liz fo shiz!!
So we may be down to 46 entrants which is still A OK!!!
Titan - Alex has PM'd and also mentioned on JDMST that he is a no go for the day :whistling: But he still needs to tell me the name of his replacement :teehee:
Dont forget wakefield now has complete LED ...
filthy ricers!
you mean the triumph? thats british, so reece's car will just surrender if it trys anything, being french and all. :blink:
I understand Reece's car also has 5 reverse gears and 1 forward, just like their tanks.
You're about as decisive as a nanny undie shopping!!! Hilarious :blink:
I will take you off reserves list now!!
And you know the funny thing... A mate has just called back (6:30am is a little early in my book, but at least he called, lol) and said he will come over and help me put it all back together tonight after work... he didn't even flinch when I said I was down in my garage until 1am this morning and when I came up the thermometer read a toasty -3 degrees!!! (I had no chioce but to put the tools down as my hands had become numb even through my gloves :D)
Problem is if I do get it all together tonight I have to somehow get it to the tuner tomorrow if it is even at all possible for him to tune it.
I really wish I could have made this one... :D
Dan.
My old man will be there in zeeee german beast, safe to say he will be the only Audi there..... :blink:
l will be there in my Triumph tr8.. the small but loud red beast. Being British however it will probably be the one with electrical problems;-)
Can I please be put on the reserves list?
Full Name: Mark Guyer
Car Type: R32 GTR
Newb or not: NOT
Most recent lap time if not newb (Wakefield): 1:07
# of Drivers: 1
# of Passengers & Name: 0
I will pay as soon as its confirmed I can run and/or cash on the day.
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
