Hi all, car = 32R
been starting to do trackdays and they gunna get more offen soon as my new wheels come so I can wrap em in semi's.
My car has HKS hyper max 2 coilovers, tein castor rod, tein rear camber adjusters but factory swat bars. I was thinking of geting a front and rear adjustable whiteline. Would it be worth it? Make it sit flatter around the bends.?
Another thing I noticed at the track last time was alot of people with 32r just changed the rear swaybar not the front one, any no why? Should I change both?
Cheers deano
https://www.sau.com.au/forums/topic/319203-is-it-sway-bar-time/
Since GTRs understeer a lot you want to have a stiffer rear bar to dial some of that out - so that's why those guys are changing that end first. Having adjustables means you can change the understeer/oversteer balance by changing the stiffness. I did both ends in adjustable whitelines. They're pretty cheap so i did both at once.
Dont buy whiteline.
Do yourself the favour and buy SELBYS, get blade type adjustment too.
do you know what spring rates the HKS coilovers currently have??
From there bar diameters can be advised a little more accuratly from experiance.
The method is simple to begin with. Medium all round perhaps a little less bar on the front if anything. If its oversteering more bar up front, Understeering more bar at the rear.
There are way to may variables to set a car up perfectly with advise and to alot of people sway bars are a placebo that makes them think their car is handling better, same can be said for spring rates.
The best way is to attend an open practice day armed with a trolley jack and some tools. Make bar changes each session. Drastic changes at first so you can identify what effects it has on the car. Then minimalise the changes as you gain experiance with the bars effects and your knowledge of interperating a cars behaviour increases.
There is nothing like experiance when it comes to car set-up.
You need to spend hours if not days deliberatly making massive changes to the car be it good or bad. That way you will have a far better seatometer as I call it to gauge a good handling car compared to a poor one or an average one.
Once you have the handle on big changes make them smaller and smaller till your stuffing around with very small allignment and geometry changes. It can actually be alot of fun if you are commited to trying it.
Edited by Risking
Ok just had a search around, these are the numbers I came up with, F=69 (7) and R=59 (6) I don't really understand what the 59 and 69 mean bit that's wat I got off the hks webby.
Anywhere anyone can suggest I get selby bars from? Online website? Or just repco it?
Thanks for everyones help so far
The 7 refers to the spring rate in kg/mm. The 69 refers to the spring rate in Newtons per mm. 1kg=9.81 Newtons.
With those spring rates the Whiteline bars will struggle to have an influence. Added to which they are heavy because they are solid, ie rod rather than tube.
Dont buy whiteline.
They are the same, bent in the same factory.
Or at least they were up until a year ago.
Slight thread hijack but since this is about sway bars this is my best bet.
My R32 GTST understeers like its going out of style, in the rain I may as well just not turn sometimes. Its only on standard rims ATM so there are all of 2 inches wide (slight over-exaggeration) But I'm moving up too 8 iches up the front soon.
Tyres are of good quality and a decent brand unlike the rears. Next planned buy for my baby is a set of decent sway bars.
What would you guys suggest?
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
