does anyone know where to buy a minispool for a R32 GTST?
what specs do I need to look out for and will the same mini spool fit any other cars? ie.. do I look for a R31 mini spool or something.
Cheers
Dan
Sell you a new diff cheap :thumbsup:
I thought the 32 had a borg warner :S
Was just thinking that if I weld it, if the welding breaks I will be stuck on the side of the road.
So should I just shim it up? I just want it to be predictable.. at the moment it reverts from twins to singles and it snaps back and piss's me off. Also picks up a tyre through a corner and spins it and Cant get the power to the ground evenly.
Edited by BANGN
and if you put anything in that has the same effect as a minispool has a chance of breaking axels so either way... your stuck on the side of the road...
Spool on weld can break axles , welds can break resulting in pinion ,crownwheel damage or launch shit out off housing :(
Can only shim clutch type diffs, most basic Nissan use Viscous diffs.
Aslyls S14 Racecar has been on a welded GTR diff without problems. GTR is easy as you can weld the clutch plates so if the weld fails it just goes back to normal GTR LSD, If you weld other types you need to weld the spider gears and when they break shit goes everywhere.
There is a tutorial in the DIY area of the forums with a guy shimming an R33 diff.
Fairly sure R32 would be similar, he's posted step by step photos and price lists for the shims as well.
I think 3.2mm (two 1.6mm shims together) is tight enough to chirp tyres while parrallel parking etc.
It will wear out eventually but should last for a good while.
I'm sure someone of your mechanical aptitude (aren't you a tradie?) could do it at work for the price of the shims/diff oil/gaskets etc :yes:
Don't weld it up/put a minispool in. I found with my old locker in early RX7, rainy days actually required me to get sideways to go around certain corners. It's easy too do because it's so predictable but would hate to have a cop around when you have to do it.
Edited by dave_rb20
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
