i own a 33 gtst and wen i purchased the car the previous owner gave me HSD coilovers the green ones they are not fitted but i was thinking of putting them in . does anyone have these installed????????? are they tolerable on normal roads or should they stay in the garage any advice would help
https://www.sau.com.au/forums/topic/320542-ride-quality-of-hsd-coilovers/
They're completely fine for the street.
They are like any stiff coilover. They're stiff.
People just seem to throw coilovers in a car without understanding how to set the rest of it up to suit.
You'll be completely fine.
I think racegtst should have developed his car a little more before pulling them out.
We've had success with multiple cars with HSDs, from VIP cars, to drift, to grip cars.
thanks guys i will put them in i have king springs but i am looking at track days so they will be a smarter option. they are the hr's
How do you find the king springs? Are they fitted to your standard struts or you using coilover king spring sports?
Was tossing up between the HSD springs vs king springs. The HSD coils are alot closer together and give less compression im lead to believe.
I have heard that there has been some fantastic success with these especially for drift but am yet to chat to someone in WA who has had success in grip but i would be keen to and also find out how they did it. I may have made a mistake but at the time the decision to change has been rewarding for me.
My previous R33 was quicker with bilstein struts and king springs. This car once changed over to the bilstein coilover setup was much much quicker but more importantly was 200% more stable and predictable. It was able to keep a big horsepower r32 GTR behind it for 3 laps.
But are opions are like aholes, we all have one!
My 2c is that a great suspension setup that suits you will beat a big hp setup most times when it comes to circuit.
On the street the HSD's were very stiff and extremly hard to read. My new setup for me anyway is much easier to read and more responsive to simple changes like tyre pressure adjustments.
I will report back in approx. in 6 weeks once i have the new swaybars, camber, caster and pineapples installed along with all new bushes all round.
  • 5 months later...
I don't understand racegtst why you bought and sold the HSD after only a short amount of time and say they are too hard?? Did you even adjust the spring preload and damper settings? Or did you you out on full hard and go nah these are shit due to been too hard?
I have HSD's in my coupe and they are fine 6 kg rear springs, less than half damper and they are fine for me! I have spent a few 1000 km trying to get it right and I'm still not there yet.
I just don't understand how someone can make a decision in no time at all.
    • I don't know if you can disassemble the thing and put it backwards for different ramp rates. They're both "2 ways" or both "1.5 ways" because well, 2 ways and 1.5 ways are the same 'thing' I do not know for sure, but I believe the 38420-RSS15-B5 is the 1 way, and 38420-RSS20-B5 is the two way. In other words, I predict Nissan considers this: to be a 1.5 way. No idea what actually happens when it arrives/you disassemble it. It would be an excellent question to ask Nismo directly! I somehow doubt you will get an answer though, I feel you would be the first person to document what you encounter when you open the box and the internet would be grateful.
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
