Hi,
Have just decided to buy a Pod Filter for my R33 and was hoping to get a box for it to help hide it.
For now im still running stock intercooler.
Has anyone used one of these?
http://cgi.ebay.com.au/SKYLINE-R33-RB25-GT...=item5887a92048
If so any feedback or pics??
Or does anyone have any experience with other boxes that are availalbe to purchase? I can't find many of these easily!
Thanks in advance.
https://www.sau.com.au/forums/topic/320693-pod-box/
good point... guess 'hide' was the wrong word :-)
never the less you kno what i mean.
Also reading the description of the item it says it makes the pod legal in most states (i doubt that to be honest)...
Still its an investment im happy to make if i can get some feedback
https://www.sau.com.au/forums/topic/320693-pod-box/#findComment-5234602
The only way its legal is if you have a stock intercooler and stock plenum or else no matter what you do , you will get done for it and this is like the first thing in a cops head these days when checking skyline pod and cooler
https://www.sau.com.au/forums/topic/320693-pod-box/#findComment-5234662
Indeed i know what you mean.
Depending on your state etc it's still illegal.
And as stated, factory airbox + good panel filter is just as good AND legal to boot (if that is what you are concerned about when you mean hide :))
https://www.sau.com.au/forums/topic/320693-pod-box/#findComment-5234865
Thanks for the feedback guys.
Yep I agree... just thought id try a pod for a while adn see what it was like.
I currently have a high flow panel filter on stock setup. I'm likely to return to it if pod gives me trouble.
All this aside, original question still stands... If anyone has bought one of these boxes Id like to hear about what they thought and what it was like.
cheers
https://www.sau.com.au/forums/topic/320693-pod-box/#findComment-5235108
I made my own pod box from some alluminium sheeting. Pretty easy if you have access to a metal bender.
I'll post up some pics tonight if your interested, or do a search for my project 33 in NSW and you should find it. Although mine has a window in it so not very stealth.
https://www.sau.com.au/forums/topic/320693-pod-box/#findComment-5239207
Yeah mate love some pics. I found a guide on installing an Apexi and making a box on SAU so im guessing thats it? I'm not too sure how well I'd go making my own!
Just received and installed my pod seems to feel more responsive but wow its loud!
https://www.sau.com.au/forums/topic/320693-pod-box/#findComment-5243571
I use one which I purchased from another vendor much cheaper and of better quality. PM me if you want their details, and I have been pulled over once and the cop didn't say anything about it.
Really depends on how they're feeling, my friend nearly got defected in his EVO8 for a FMIC, the cop kept on insisting it was aftermarket although all EVOs come stock witha FMIC lol.... was hard to hold in our laughter!
https://www.sau.com.au/forums/topic/320693-pod-box/#findComment-5244076
^^ As long as it is a high flow one.
APex'i / HKS / K&N they all do the job.
You can clean the filter with the K&N Cleaner Kit.
Unless you want to spend an extra $100+ each service buying a new filter...
Apply the cleaning solution to the filter and let it soak for 10mins.
Hose of with tap water and let it sit and dry in the sun.
You might even want to flick the filter to get rid of some excess water to speed up drying time.
K&N Cleaner Kit also give you an oil spray, no need to use it, but if you do, just a light spray only to catch excess particles.
DR/FT brand?! = Get the fuck out! :P
https://www.sau.com.au/forums/topic/320693-pod-box/#findComment-5245941
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
