We normally use the Garrett Big can actuators which is rated upto 23psi. We can also modify your turbine housing so your boost curve hold flate to 7000RPM.
The ceramic turbine wheel is my only concern. It might breaks off under heat and pressure just like the OEM turbos do.
  • Replies 53
Car is now boosting alot earlier due to finding
a couple of boost leaks.One was found by myself which was an intercooler pipe joiner being loose and the other one was found by Daniel at Elite Racing developements when i took it to him this morning.Car feels much livelier and more like i anticipated when buying the turbo.After the leak was fixed we took it for a drive and the clutch didn't like the extra torque and started to shit itself.So one problem fixed and one to fix as soon as possible.All in all very happy! As for what Rad32 said about a steel wheel version i think it might be cause my mechanic said that the compressor wheel had markings on it which were still quite fresh which indicated it had recently been rebuilt and balanced.But i wont be able to test its limits until i can afford to put bigger injectors and AFM on it.So thanks to every one for their input in helping me with my teething problems as i wouldn't have known where to look without this forum.Thumbs up to SAU. :P
  • 2 months later...
Bringing this back alive just to add that the wastegate on these turbos is adjustable stock (screw fitted arm). I got mine from Darrynspencer on here - adjusted to 9psi then put a boost controller on it (ID3) and tuned at 11, 13 and 15psi (above 13psi boost drops off at the top end a little).
Full boost (15psi) at 3500rpm on the dyno and road when tuned, made 227rwkw. But boost was dropping off to just under 14psi. I think I could wind another 2 turns on the actuator to get ~11psi without controller and fix some of that pressure drop off, set controller to run 16psi and probably max out at 240rwkw.
i had one of these turbos on my s14 (but a p20 version) and it was laggy ish but it is a big turbo a p25 is rated at 550-600hp i vaguely remember so lag is kinda expected but urs looks a lil too much, i dont have a dyno sheet handy but i gave the turbo to my best mate when i sold the car stock so ill see if he has a printout somewhere
SR20's use a AX53B60, not what we are talking about here
AX53B70 P25's are rated at 380hp not 550-600hp
yeh, after adjusting the wastegate actuator i am getting 16 psi by 3400rpm.I found that my actuator does not control boost level but controls how fast peak boost is achieved . Without the bleed valve connected i reached a peak boost of 12 psi.Cheers.
  • 1 month later...
ECR-033, at 18psi I think you are over-boosting that turbo.
Better to drop a couple of psi and be happy with 230rwkw than blow the rear wheel off. I doubt that extra 2 psi is giving you much power anyway. I make 227rwkw at 15psi mid-range (dropping to 14psi up high).
4th gear with ebc = full-boost at 3300rpm (1 bar), 7psi at 2800rpm.
Skylinatic, your midrange torque is amazingly similar to mine at ~520Nm calculated flywheel. I doubt you'll get much more out of the turbo though, maybe another 10hp or 20 max.
Edited by simpletool
I put the boost down to 16psi, went past my tuner and asked a few questions about the turbo. he said it is completley safe on 18psi and its not a ceramic wheel its 100% steel. i also rang up a few other places and they all say the same thing, all say its steel wheel turbo.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
