Bloody thing is still overheating, now its getting worse.
Last night, even though the water temp was around 90, the heater wasn't working at idle. As I started driving, it worked again. Driving down the freeway the temperature hovers around the 89 degree mark but as soon as I slow to under 60, the temps shoot up to 108 or more. This should not be happening on an 8 degree night. I am guessing the water pump is on the way out as I have already replaced thermostat, I installed a mishimoto race radiator and i'm running the motul additive.
Anyone know how to change the pump? Looks like I now have a reason to fit the new silicone radiator hoses I bought. :)
https://www.sau.com.au/forums/topic/321053-m35-overheating/
Does your new radiator have the factory fan shroud re-installed, Scott? It's pretty surprising how much this can affect airflow through the radiator.
I couldn't fit it. I was going to make an alloy one eventually, but that wouldn't explain the heater not working. Looks like they only last around the 100k mark on the 350z. If they run the same pump, they are around $125us shipped.
The pump runs off the timing chain so it will be a big job, i'm not looking forward to it.
https://www.sau.com.au/forums/topic/321053-m35-overheating/#findComment-5239121
I still reckon you have an airlock.....DON'T BUY A WATER PUMP.....I have a brand new JDM one that has never been used....I bought it when I was having the same problem as you.
If you don't think it's an airlock still I'll sell it to you for what I paid.....I have something going down to VIC tomorrow so I can put in in that parcel if needed.
As far as changing it........apparently it's a huge job! Have a look at the V35 manual.....If that doesn't show you get Ian to scan the jap manual for you.
https://www.sau.com.au/forums/topic/321053-m35-overheating/#findComment-5239167
I think it's much more likely they system is not bled properly - the heater is not working because there is a big air bubble there probably.
Have you replaced the coolant, and if so what procedure did you follow to bleed it. You should run the heater on hot while bleeding, prefeably with the nose of the car pointing uphill. There may also be a bleeder on the engine block you should open, certainly is on rbs
https://www.sau.com.au/forums/topic/321053-m35-overheating/#findComment-5239172
This is about the 20th time I have bled it. The bleeder is at the back of the block on the heater hose. I cracked the bleed point last night when I was having the issue and coolant came out so unless there is an airlock elsewhere in the system I am stumped.
There were definitely air or steam bubbles going into the overflow when it got hot.
I still don't get why it runs fine when the revs are up, points to the impeller loosing a couple of blades doesn't it? I need to refit the low temp thermostat and silicone hoses so if there is a special "bleed while upside down with your tongue to the left" procedure post it up Craig and I will follow it.
https://www.sau.com.au/forums/topic/321053-m35-overheating/#findComment-5239216
Tongue to the left procedure:
1. Go to the bottle O get 6 pack of beer(or a shandy in your case Scott)
2. Drink beer before arriving back home( Also know as the 6 pack holiday)
3. Contemplate not doing it at all....also know as the "she'll be right mate" symptom.
4. Go to walk inside house figuring out the wife is there and she'll make you do house chores.
5. Call a mate to pick up some more beer as the one's that you bought 10 minutes ago were gone before you got home.
6. Wait for mate to arrive with new supplies
7. Get mate to take you for a spin in your car as you are too drunk to drive....also a useful task to get the heat right up in the radiator.
8. Open bonnet and bleed while car is still running with tongue hanging out to the left.....probably burning your hand in the process....you wont feel it till tomorrow though!
9. Drink more beer winging about how much you hate the car ATM while the car cools.
10. Repeat process's 5 - 9 three more times.....you will know that the car is properly bleed when you cannot get anymore mates into the car for a spin around the block.
11. Next day....try to remember whether you did it right....if car overheats again start the whole process again.
cheers
Craig
Edited by Jetwreck
https://www.sau.com.au/forums/topic/321053-m35-overheating/#findComment-5239243
Seems better... The only thing I did different this morning was bleeding it while cold. I will see how it goes.
It definitely had air in the system, I put about 200mls in the bleeder with a large syringe and it seemed to do the trick. I will check it again later.
I have never seen a system so hard to bleed before.
https://www.sau.com.au/forums/topic/321053-m35-overheating/#findComment-5239382
this is how i bleed most rads (31 is a bit of a pain to do)
grab a 600 ml coke bottle (or any soft drink)
cut off the bottom
tape up the top till its a snug fit inside the radiator filler
squish it in a bit so it seals off
pour water into it
turn car to "on" position but not started
crank heater onto hot as a mofo setting
open that bleed bolt and take it out
squish the rad hoses and the heater hoses if you can reach them
i had a problem with a few mates cars after we drained the coolant, got a massive air lock in the system and it didn't wanna come out
eventually it did and it needed about another 2 litres of coolant putting in
can you remember how much you put in?
https://www.sau.com.au/forums/topic/321053-m35-overheating/#findComment-5239460
Couldn't agree more.
If it still ain't right, try parking with the nose downhill and finish filling using your "Dandenong" syringe via the bleeder.
I have found it is the most thorough way of getting all air our of the system. It does take some time though
EDIT: pipster11's method will usually work though and is the same method I use to change the coolant (although I DID get a small air lock last time)
Edited by iamhe77
https://www.sau.com.au/forums/topic/321053-m35-overheating/#findComment-5239462
i usually god for a quick drive and watch the temps then crack (but not remove) the bleeder bolt while hot (although the jap sticker says not too) and wait for the bubbles to piss off
That is what I have been doing but it doesn't seem to work. Like I said there was fluid at the bleeder when hot but 200mls down when cold. There doesn't seem to be any leaks, it just holds a lot of air in the block obviously. I will keep bleeding it when cold and see how that goes.
https://www.sau.com.au/forums/topic/321053-m35-overheating/#findComment-5241206
My citroen BX GTi 16V needed some wierd arse additional expansion bottle to be fitted when the cooling system was bled.
Because the top of the engine was physically higher than the normal models they used this additionl bottle. It had a bottom like a radiator cap, that fitted into the top of the expansion bottle. They filled it with water, now some 20 cm higher than normal, and then started the engine with the heater on melt down setting. Once the thermo opened, they would bleed it, wait for the engine to cool down a bit, remove the extension bottle, suck out a bit of the water to get it back down to the correct level, and send you on your way...
I'm pretty sure that something similar was required for the Rb30 in the VL, because the radiator cap was "too low".
https://www.sau.com.au/forums/topic/321053-m35-overheating/#findComment-5241305
yeah same sort of solution pipster11 said, that's how we do the race car too but its easy without a heater box.
to be honest i think its just luck sometimes....these systems are very complex and big air bubbles can form :P
https://www.sau.com.au/forums/topic/321053-m35-overheating/#findComment-5241392
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
