Haha yea that is a big LOL I'd put a brandnew
pod in and chnged the plugs and the oil
and oil filter plus the fuel filter still the same.
What else can I do?
250km per tank would actually = 26L/100km, as the R33 tank is 65L.
When you mean per tank, do you mean when the light comes on? or when the needle hits E?
Because if the light comes on, you still have 10-15L left in the tank....
you need to retard the modulation of the throttle lever.
Hold on, i think there is an important hint here we are ignoring...
(by the way i was calculating 60L, 5L remaining for pussying out and stopping at the nearest petrol station :()
Edited by TyresBro
I would replace the o2 sensor first. I gained a a bit by doing this yet alone an o2 sensor that has probably never been changed.
Factors such as agressive driving and heavy traffic will naturally kill fuel consumption.
I consistently average 12.5L/100km with the odd squirt of acceleration and well moving traffic.
wow 250km per tank, that makes my 330km per tank without the light feel beter. got many mods, had it tuned yet?
That's pretty much what I get.
I'm hoping and expecting a Nistune and dyno time to improve it somewhat.
I've done filter/plugs/oil.
Will check the o2 sensor.
wasn't o2 sensors mentioned before?
Then he found out the tank is leaking fuel out and also the o2 sensors are stuff!
Correct, correct, and correct.
RB25DET sees massive improvement by replacing the oxygen sensor. They don't last at all, so chuck in a new one every 80,000km or so. I netted an extra 100km or so per tank out of changing it. Even fanging your car everywhere should see more than 250km per tank.
