  • Replies 78
Posted Images
^^^ ROFLMFAO Nigel .... Freddy Got Fingered is one of my all-time f**ked-up favourite movies! (You also needed to put in the 'puppet on a string reference' to make it funnier) :)
No-one ever looked so good wearing a suit backwards :):P:D .... if you ever doubted that Tom Green is a disturbed individual (and Rip Torn too for that matter), then watching this movie would certainly confirm it :)
+1, that movie is f**king win. Loved the Tom Green show as well!
Who would have thought Tom Green was such a talented wordsmith - that is extremely difficult to do on the fly for that long.
.. because hes reciting pre-made's that were done to death in the 80s lol
theres loads of mcs out there that spit hard rhymes, but most of them have them all memorized, and they sometimes make the fatal mistake of repeating those lines more than once, xzibit and canibus have done this quite a lot...as opposed to true freaks of nature like supernatural
-D
Tom Greens forte isn't rap battles, so regardless, the mans a genius for even remembering all of that. And then being able to spit it out to a tune and not f**k up, thats a talent in itself.
See you guys at 9am!
For those attending but not in the car display or shopping in Repco, please park in the Bunnings carpark around the back, as not to clog up the small carpark which other business's use - this will be strictly enforced.
Nigel.
    • Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
