Whole list of parts for sale from my 1999 R34 N/A GT-four sedan.
Front seats $200 pair with rails
Rear seats $150
All seat belts $200
Parcel shelf with 4 tweeter holes cut out $50
Roof lining in black velour $150
All pillars in black velour $60
Fuel tank $250
Front bar $200
Front guards $ 200
Bonnet (couple of stone chips/pin dents $250
Bonnet latch $50
Bonnet hinges $50
Cusco Master cylinder stopper $80
Glove box $50
Kick panels $80
Door Trims $100
Cusco Full bolt in cage $1200
Brake master cylinder $120
R34 GT-four gear box, Small crunch 3-4. Chuck some redline in and she'll be right, Complete manual conversion $1200 Will include clutch master, pedal etc
Clutch pedal $120
Clutch master $80
Brake pedal $50
Accelerator pedal $50
R34 N/A brakes complete set, discs, calipers, lines $300
R34 N/A air box $50
All Air con stuff $200
Brake lines $50
Heater box (non leaking) $150
ABS module $150
Climate control display $150
Bnr34 brembo's low k's, slotted rotors, A1RM pads, braided lines, complete set $2800
R34 Rear hubs, handbrake set-up, handbrake lever, lca, $300
If your after a stock part that isnt there let me know.
Will be adding more as i think of it.
Cheers Luke
https://www.sau.com.au/forums/topic/322680-lots-of-r34-parts-4dr/
  • Replies 47
hay buddy
ill take the ac control unit for 150
and the a pillars retrimmed in velour if they fit a coupe ill also take them
also where did u get the carbon inserts for the dash and the doors?
and
where did u get ur dash flocked/retrimmed?
i also spoke to u a lil while ago about a greddy oil filter relocation kit sorry i didnt get back to u i bought one brand new
cheers
julz
Edited by GUN_METAL_GTR32
Wondernig if you are interested in selling your CF centre console garnishes. The gear stick + ashtray surround mainly. THey should fit in a 34gtr yeh?
Probably wont sell that just yet. Not sure if im gonna use it or not. If i do sell i'll let u know.
Also forsale BNR34 injectors $330
All Pm's sent to :yes:
Edited by Luke_ENR34
Man why you gotta do this now? Id so have that cage if i wasnt in the middle of doing a shit load of work on my house. Wanted a jap cage for my 34 for ages...
Could always make a offer :)
Will update with pics soon.
Also got:
R34 Steering wheel with airbag (manual) $200
Passenger Air bag (been retrimmed) $100
Random RB26 oil and oil lines $50
Random RB26 Bov's, piping $250
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
