I was wondering what your experiences are with front pipes, I am thinking about getting a Just Jap stainless front pipe are these any good? They seem cheap compared to others, Is it because its not a big brandname?
Thanks
https://www.sau.com.au/forums/topic/323077-front-pipe-for-rb26/
i bought and installed JJR front pipes to my GTR in Feb along with a 3" high flow cat...i also wrapped mine with exhaust wrap to keep the temperature down.
they come with new gaskets/bolts and bolted up with no problems, they are a good upgrade for the price, i noticed my car boosted sooner/harder/louder
no probs with em, each pipe is about 60mm in diameter (inside) and merge to 76mm, the japanese ones are 70mm into 80mm
ps. stock ones are 45mm inside diameter ! hahaha
Edited by SiR_RB
Awesome thanks for the Input guys JJR front pipe here I come. Atm the car is pretty stock power wise but has had handeling mods done. I would like to eventually make 250-280 awkw but that will be years down the track.
Thanks again for the prompt responses
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
    • I _think_ that one has a christmas tree or some other retainer spike into a hole in that panel under it. Come in under it with thin scredrivers and just pry it gently up. If you rip the ears off the retainer pin....so what? Just stick it back down after with a bit of race tape and carry on with life.
