Missfire Boost@4500-5500 RPM - The Answer! (for me at least!)
i had the same problem as soon as i hit 4000-5000 rpm it it will missfire even on low boost
i put new plugs in it [bPCR6E 0.8mm] ran ok on low boost but as soon as you put boost in to it it runs like shit
so i tried to silicon the coil pack still no good then i went and bought new coil packs splitfires runs heaps better
no missfire as soon as it comes on boost it starts pulling and then about 4000-5000 rpm it doesn't seems to pull as hard
and then it starts pulling again so im thinking i might need to try a colder plug or smaller gap
any suggestions would be appreciated thanks
Sounds like it is just running the standard tune, you get a torque dip around 4-5000 rpm (normally peak torque) due to the tune richening up for safety, pretty normal and if you look at dyno sheets of stock tunes you'll see this common dip in the midrange.
Remap should sort you out.
I have just bought a R32 and it does the same thing. When I first drove it home it would start misfiring at 3000 rpm but after mounting the ignitor so it wasn't floating on top of motor and fixing dodgy wiring it now gets to 4000-4500 rpm before misfiring. Also when I tried to give it a squirt it reached 4000 rpm in 3rd and just wouldn't rev any harder. Didn't misfire or anything, just wouldn't rev any harder.
I have been told to check spark plugs, coil packs, and the wrap tape round the spark plug technique. Aswell as being told it could be crank angle sensor, oxygen sensor, blown head gasket, or even pistons and rings.
I have just grabbed some standard plugs and I am going to check coil packs as I can't afford those yet and have it booked in for compression test.
Anymore advice I can be given would be highly appreciated!
Hi guys,
I am having a misfire problem with my series 1 r33 however it is occuring at all rpm ranges, anything more than 25% throttle and even at idle. I hadn't driven it in 7 weeks because i broke my ankle and when i started driving it again it was running absolutely fine for 3 days until last night when i was taking off lightly from a set of lights.
I am running fmic, emanage ultimate ecu, avc-r boost controller, 3 inch exhaust, pod filter, bosch 040 fuel pump, stock turbo at 10psi. The spark plugs were replaced 4 months ago, so I am thinking it is possibly coilpacks. Has anyone experienced a similar issue? I don't think it is fuel or ecu related as I have been running the pump and ecu in my car for 6 months with no problems.
Any help would be much appreciated.
- Sam
  • 3 months later...
now i may have a similar problem:
on the rb20det running 10psi and plugs at 1.1 i've changed my regular coil packs to a spare set i had laying around that i believe are newer/ in better condition.
now the problem i'm getting on full throttle is a splutter from 4k to 6k RPM, i already get a back fire (exhaust POP) on/off throttle at around 3k. my original coils dont splutter above 4k so is the splutter the missfire we are talking about or just wear and tear ?
  • 4 weeks later...
Probably already posted but.. I thought I had a misfire but it was in fact the ball bearing in the manual boost controller that had rusted which was causing big stutters under acceleration. Something worth checking out, I didn't drive my car for approx 3 weeks and then it started happening.
  • 4 weeks later...
Hey fellas i have an SAFC and i think i may have the same problem!!
And ive just had it tuned also :D (by a very respected tuner)
Thing is he tuned my car on a 27degree day and it gets worse when the weather gets colder!
Maybe its not a miss??
I also get a pop out of my zorst in between gear changes is that related??
Cheers
Hi hoping you can help or anyone? i am new to skylines, just wondering if this is right (ill try explain in my own words!) driving the skyline, increasing throttle, rpm hits and then about a half second delay then the goosh boost sound comes on, then further up the rpm again around 7000 rpm another 1 sec delay like the car hits 7000 and holds it for a second then the boost kicks in? is this normal for the car to hold for a second before the boost hits in? doesnt feel right to accelerate and then feel it spool up but takes a second for that boost pop sound? can someone enlighten ME :)
What is a 'delay' ? Is it a misfire (pop pop pop)? Does the engine completely cut ignition? Does the engine splutter, does the engine just make no power? Is the engine pinging/detonating (sounds like a can of nails being rattled around) ?
Answer these questions and we can help you.
This makes absolutely no sense. "Rpm hits" what doest his mean, rpm hits what? at 7000rpm theres a 1 second delay before it hits 7000rpm again?? Sense makes none.
What does "boost kicks in" mean?
Edited by Rolls
im new sorry, and its like there a half sec of nothing then a pop kinda sound when the turbo cuts in? and not ignitition its like it holds for a second before it pop or makes the turbo sound like a pop as there is no BOV there is a slight sound at the rear? and not rattling just puff or pop sound when it gets to a certain RPM range and then it feels as if the turbo cuts in but its like a lag before the turbo cuts in and or pops
I'm a little confused by the description mate, and think that it would greatly help you to read a fair bit of this thread (at least the last 5-10 pages), then see if the problems you describe are similar to those others have had fixed.
  • 4 weeks later...
I checked the tape i put on my coils after having it on for a good few months and the tape was still exacly how i left it.
so it depends on how you wrap the coils and what quality tape you use.
Go to an electrical wholesaler and ask for "self amalgamating tape" it stretches back on to itself. The best insulator and is resistant to high temps too. Good shit for exactly this type of application. Better late than never ermm.gif
Edited by carcass
  • 3 weeks later...
i got my tape from my local chandlery
They didn't know what self amalgamating tape was, theirs is called RUBBAWELD
probably cheaper from an electrical wholesaler (mine was $12.95)
put it on, (bought 2 rolls but only used 1), seems pretty good
i don't think my coils were dead yet but they'll last a little longer now
I have a miss in my r32 gtr after about 4500rpm, car still pulls but its asif its spluttering whilst boost is on. Im running splitfire coilpacks with std ngk plugs gapped to .6, boost is set to 16psi with a tuned pfc ecu and basic bolt ons intake/exhaust/fuel pump/injectors. Spark plugs have been in for about 4-5000kms, took them out and they look fine, also realised the car is running a bit rich, alot of poping going on wen on light throttle between gear changes.
Any ideas?
Edited by DVSTRK
Could the plugs be too cold?
Wrong plugs can lead to a world of frustration
Not sure, i had the impression that as long as the spark plugs are changed regularly it doesnt make much difference with expensive ones, i realised it happend after one of those really hot days last week or so, cars running temp was stable, is it possible for the sparkiz to just let go or fail at certain revs, recently after one of the miss/splutter expirience the car dropped a cylinder sounded like a rexy, check that all coilpack plug ins were in proper contact, no issues there but after i turned the car back on all 6 cylinders were firing.
Edited by DVSTRK
^Hate to say it, but that was what my r34 did when it's stock coilpacks went. How old are the splitfires?
No more than a year old, i also noticed the splutter happens after i drive the car for abit.
Grabbed some iriway plugs, going to chuck em in soon, hopefuly its just a faulty plug.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
